2006 Impala won't start - Impala Tech
post #1 of 1 (permalink) Old 02-12-2013, 10:38 AM Thread Starter
Unhappy 2006 Impala won't start
I have a 2006 impala and it won't crank. I put the key in the ignition and all the dash lights and radio power up just like it's supposed to but the engine won't crank. It makes no sounds and the engine sits as if it's getting no power. I also do not hear the fuel pump pressuring up. It does this intermitanly. I have also had a reduced engine power light on that lights up and comes on but this problem is less often than the not cranking. I thought I would mention it in case the two are related. It should also be known that the car will crank over fine for a couple months and then not crank over and again then start like a brand new car. Please help me figure this out.
Mjsk is offline
