Anybody know how much to shorten the front half drive shaft from a cast iron PG to a TH350? Probably just measure the overall length difference and have that much removed (appears to be about 3") but thought somebody might have done this before. Also will need to change the yoke as the old PG has coarse spline and the TH350 has a fine spline. They're readily available but not sure if the yoke connects with the drive shaft U joint without modification. Thanks!
