62 wagon big block - Impala Tech
post #1 of 5 (permalink) Old 03-18-2017, 07:52 PM Thread Starter
62 wagon big block
working on getting car on the road. If I got a posi center section for the stock rear how will it hold up? 454 with turbo 400 ,,,600 hp for street use with occasional hammer
thanks,
Doug
godtar01 is offline
post #2 of 5 (permalink) Old 03-18-2017, 09:45 PM
It won't.
Your rear end was designed for a 235 six cylinder not a V8. That is why GM replaced the whole rear end with the Spicer series of modified Dana rears in 1965. GM did offer a rear end designed for V8's and a straight eight Olds with the strongest ones made from 1957 through 1964 and where under all of GM's cars except the Chevy.
You can still find them on flea-Bay:
1957 58 59 60 61 64 PONTIAC OLDS REAR 9.3 AXLE HOUSING | eBay
These rear ends will handle 1,500 horsepower easily, and it looks like a Chevy rear end just with a bigger pumpkin to hold the bigger gears.
post #3 of 5 (permalink) Old 03-19-2017, 11:03 AM Thread Starter
I could not find a way to upload a photo. I am a new free member do I have to upgrade?
Thanks,
Dave
godtar01 is offline
post #4 of 5 (permalink) Old 03-19-2017, 12:07 PM
Thanks,
Dave
NO Absolutely not!
Follow these instructions and you can post photos on any web site (that uses HTML).
posting photos using Photobucket - Nova Tech
This was written by a mod over on Team Nova but it works here and just about everywhere.
post #5 of 5 (permalink) Old 03-20-2017, 02:16 PM
Lifetime Premium Member
even at 500hp/tq, I think you'd either need what Dave mentions, or just go aftermarket like Currie, Drivetrain Specialists or Mark Williams or something. besides the beefed up gears/posi-unit, the axle tubes will probably need to be welded to the center section I think. My '66 10-bolt model and many GM others only had small pins keeping them pressed in place.
Too much torque/traction can cause the tube to rotate which is sooo not good.
