Push back and up on the seat bottom, they're sometimes not easy to do, to remove the bottom; then there are to bolts holding the seat back in remove them the pull up.
There is a stamped steel bracket welded to the floor that forms an "L" shape there is a wire rod that hangs down on both sides that fit into the "L". So as you push back it unhooks it.
You can actually see the bracket on the floor pan if you get your head down there and grab the corner of the seat and pull up. This will show you where to push back.
Man it doesn't get any cooler than this!!! I found my original build sheet underneath my seat! It's in almost perfect condition to boot!
Very cool!
