New Toy 66 impala 66 convert progress thread - Impala Tech
post #1 of 16 (permalink) Old 06-04-2017, 11:07 AM Thread Starter
Hey all going to put all my progress here
So i took care of the leaky rear wheel cylinders and brakes.
Also threw in a new battery, car was charging but battery didn't hold charge.
New Air filter,Gas filter, Plugs ,cap & rotor also points were new checked dwell 30-32.
Ordered front shocks as well, one was leaking on the pass side. somebody put air shocks in the rear.
I usually rip them out but leaving them in place for now.also there is the Orig numbers block in the trunk.
impalajohn is offline
post #2 of 16 (permalink) Old 06-04-2017, 03:18 PM
Blocks are not that heavy. Pull that sucker out of the trunk and store it inside in a plastic bag that is air tight (to keep moisture out of the engine). If not, and you drive the car around, the block rolling around in the trunk will punch some interesting dents in your fenders that have to be cut off and a patch panel welded over the hole because the metal is stretched to far (assuming it doesn't go through ) to be shrunk back and hammered flat.
post #3 of 16 (permalink) Old 06-08-2017, 10:41 PM Thread Starter
Hey Dave,
Yes i will, but that sucker is heavy, So i installed the front shocks greased the front end and checked the front wheel cyl they were ok and i greased the front bearings up.
post #4 of 16 (permalink) Old 06-09-2017, 09:41 AM Thread Starter
So i am having issues with the carb there was alittle dirt in the filter again.
i put an inline filter in, now it seems the carb needs to be taken apart to clean it out.
I think the float is getting stuck. runs alittle rough now and then like it wants to stall.
It's not dumping gas,
post #5 of 16 (permalink) Old 06-09-2017, 12:49 PM
You may have to drop the gas tank and clean it out. After that it will need to be sealed with epoxy paint; as gasohol is acidic and eats the galvanized coating allowing the mild steel tank to rust otherwise.
The tiny flakes of rust are being continuously agitated by gas sloshing around in the tank, and picked up by the fuel pump. There is a cloth sock on the end of the pick up tube but I do not know the condition of that prefilter after a half century.
post #6 of 16 (permalink) Old 06-10-2017, 09:01 AM Thread Starter
Correct
post #7 of 16 (permalink) Old 06-10-2017, 09:18 AM Thread Starter
carb
cleaning this carb up later model 74-77 bigger quad 4 barrel
post #8 of 16 (permalink) Old 06-10-2017, 12:12 PM
The biggest QuadraJet made in that time frame was off of a 454 in a Chevy one ton, or three quarter ton, C-K-G light truck. It was rated at 780 cfm.
The 350 in this time frame was rated at 620 cfm and the 305 was rated at 530 cfm. Differences were in the primary bore size and if it had a secondary booster in the primary bore.
Nice thing about a QuadraJet carb is that it can not be over carburetored as it operates off of manifold vacuum. Put a 780 cfm on top of a 350 and it won't flow much more than 620 cfm as it is air flow through the back barrels that determines the total cfm flow rate. If the demand isn't there the back barrels don't even open; which is why you don't see them fully open when you blip the throttle. Small primary barrels offer great throttle response and mileage, plus you get that great QuadraJet sound when the back barrels do open up.
post #9 of 16 (permalink) Old 06-11-2017, 09:56 AM Thread Starter
Exactly Dave!
Well the carb turned out great. Runs good, idles good.
did alittle detailing under the hood too.
post #10 of 16 (permalink) Old 06-11-2017, 10:03 AM Thread Starter
Seat belt cleaning up
Took out the back seat and vacumed up under there and cleaned the front seat belts still working on rears
Aslo installed a new Gas pedal, surprise the other one was broken
ID:	18114   Click image for larger version
ID:	18122   Click image for larger version
ID:	18130   Click image for larger version
post #11 of 16 (permalink) Old 06-12-2017, 10:01 AM
Correct
I recommend replacing the tank, especially if you intend to drop the old one. Getting the old tank CLEAN can be tricky and re-cleaning the fuel system gets old very fast.
If you wish to replace the tank, Spectra (from Canada, and sold by several vendors) sells new direct replacement galvanized tanks for about $150 (2x that much if you opt for stainless, which I think is overkill).
japete92 is online now
post #12 of 16 (permalink) Old 06-12-2017, 10:29 AM Thread Starter
Recarpeted the console fixed light to
post #13 of 16 (permalink) Old 06-12-2017, 10:31 AM Thread Starter
Few pics after quick cruise
ID:	18154   Click image for larger version
post #14 of 16 (permalink) Old 06-12-2017, 11:03 AM
Lifetime Premium Member
I had those Rally wheels on my gold 66 vert. (in my profile/garage) your pics remind me of it. Looks good!
post #15 of 16 (permalink) Old 06-12-2017, 11:53 PM Thread Starter
thanks BA, still have it?
post #16 of 16 (permalink) Old 06-13-2017, 03:08 PM
I sold that one to a fellow from Chillicothe, Ohio. He honestly said he just planned to use it as a weekend car and take the family out for ice-cream.
it was a really good car, if I didn't have this current black one, i'd miss it more.
