1966 Impala 327 - Impala Tech
Performance Our High Performance Area
Old 11-06-2010, 11:36 PM
Brandonion1985 Brandonion1985 is offline
Brandon
Brandonion1985 is on a distinguished road
Default 1966 Impala 327
I have the 4 door hardtop and have seen around online that there were a couple types of 327's put out that year with different HP. Was wondering how I could tell what one mine was. I do know that I have the 4 barrel carb but other than that not much more.
Old 11-07-2010, 12:31 AM
Big Dave Big Dave is offline
Default
They all came with a four barrel. Only the 283 came with a two barrel. Base horsepower was the 275 horse engine. There was also a 300 horse a 350 horse and a 375 horse variant. The two top engines had camel hump heads and mechanical valve tappets instead of hydraulic, the 375 was a Corvette only option and was fuel injected, and the 350 horse was equiped with a Holley. The two lower horse variants had a small triangle on top of the base rectangle called a Power Pack head and used a Rochester Quadrajet.
  #3
Old 11-07-2010, 12:51 AM
dcairns dcairns is online now
David
dcairns is on a distinguished road
Default
According to my book (Chevrolet by the Numbers), only the 275 hp was offered in the full size passenger in '66.
If you look at the stamp pad on the front of the block, you should see one of these suffixes:
HAH - manual trans, Holley carb
HAR - manual trans, Rochester carb
HB - A.I.R. (air injection reactor)
HCH - Powerglide, Holley carb
HCR - Powerglide, Rochester carb
HF - Powerglide, A.I.R.
KE - Heavy Duty Clutch
__________________
1964 Impala 4 door sedan
My Bloggy Thing: http://www.impalas.net/forums/blog.php?u=2285
  #4
Old 11-07-2010, 01:20 AM
Brandon
Default
K thank you, just got this car a couple months ago and I am trying to learn as much as I can about it. another question I had was when it comes to gas I have been using regular and adding the lead additive to my fuel when I refuel. I have heard that you can do something to the heads on the engine so that you don't need to add lead substitute. How much does it cost on average to have that done to the stock heads and is it hard? Aslo could you swap out the heads for another year sbc head and not loose horsepower?
  #5
Old 11-07-2010, 10:51 AM
Default
You probably have enough lead build up in your motor now so that you can forgo adding the lead (which is highly carcinogenic) and just run high test (91-93 R+M Octane) in your motor. The base 275 horse 327 shipped with flat tops and a cast 64 cc combustion chamber for a 10.25:1 static compression ratio. You are probably running closer to 9.2:1 dynamic compression now which is within the limits of pump gas.
If you experience any detonation add one gallon of Toluene (lacquer paint thinner) to you full tank of gas to raise the octane (R+M) up to about 95 assuming you add one gallon of Toluene to 19 gallons of gasoline.
Newer heads all have hardened valve seats (cast iron is brittle but has a low Brinell hardness number of about 120-150 for gray cast iron so it is considered soft). A hardened valve seat is nearly ten times harder and will not erode the way the cast iron will. Any late model head except the Vortec heads made after 1996 will bolt up to your car and have hardened seats. Unfortunately it will also have larger 72 to 78 cc chambers to drop your static compression.
You get free horsepower with higher compression which is why all of the muscle cars of the late sixties required 100+ octane premium pump gas to run (Sunoco Blue 260 was rated at 104 octane which is considered to be racing gas today).
  #6
Old 11-07-2010, 11:07 AM
David
Default
You could also get your existing heads rebuilt with hardened seats. This is the routine thing to do with any valve job these days.
__________________
  #7
Old 11-07-2010, 11:46 AM
fsc66 fsc66 is offline
fsc66 is on a distinguished road
Default JUst for the record
As stated, the full size chevrolet offered the 327/275 HP only. There were however 2 versions of the 283. 1 version was the base model 283/195 HP single exhaust and then the 283/220HP 4 BBL dual exhaust version. Both 283 versions offered only the flags on the front fenders, the 327 offered the flags with the 327 emblem above them.
Paul
__________________
Paul
1966 Impala SS
Please Visit our new site:
http://www.winvoices.com/
1960 through 1970 window stickers, car shippers, dealer invoices, retail sales orders and tank stickers, expertly reproduced, for all Chevrolet Models.
  #8
Old 11-29-2012, 10:49 PM
Speedi D Speedi D is offline
Don
Speedi D is on a distinguished road
Default
The 327 I put in my '57 has an cast date of B147 (3/17/67) and assy. date of 0306 (Mar 06). It came out of a wagon. It was the 275hp version, HF suffix, w/hyd lifters, a Q-jet, thin steel head gaskets, pistons w/valve reliefs and 462 camel hump heads, [and a cam w/3 flat lobes]. The cast dates on the heads and intake are all Feb '67.
Last edited by Speedi D; 11-29-2012 at 10:53 PM. Reason: Jus' tryin to get it all together!
You may not post new threads
You may not post replies
Forum Jump
Similar Threads
1966 327 Engine Labels dbuchholtz Restoration Corner 2 10-06-2009 08:26 PM
What Parts Catalogs for 1966 Impala Jeff_Impala66 Restoration Corner 10 07-06-2009 11:26 PM
E85 in my 1966 Impala greenimpala Engine 14 07-22-2008 06:32 PM
65 Impala SS 327 in a parts car 65 pimpala Engine 5 06-21-2008 06:46 PM
1966 impala door glass westonz28 General Tech 2 01-04-2006 07:47 PM
2009 AutoForums
