found battery current drain issue need help - Impala Tech
Electrical & Wiring Troubleshooting electrical problems
Old 06-16-2011, 08:28 PM
fatchysc fatchysc is offline
John
fatchysc is on a distinguished road
Default found battery current drain issue need help
I have a current drain that kills my battery over ~3 day period if I don't charge the battery on my 2001 Impala LS.
I put an ammeter on & started pulling fuses & relays in the underhood electrical boxes. I found that when the RTIP #3 60A fuse in the 'Bottom' CTR box is removed, the current drain goes away.
Would someone help me identifiy where to go next? What is connected to this fuse?
Old 06-16-2011, 09:30 PM
John
Default
well....I kept digging & found out that when I pull the 15amp fuse for the radio, the current drain goes away. This is the factory radio with CD & tape player. I figure I'll rig up a new power switch from the fuse block so I can turn it on when the car is running & stop all power to the radio when the car is off.
You may not post new threads
You may not post replies
Forum Jump
Similar Threads
jump starting a battery. Pimpzilla Electrical & Wiring 3 11-07-2010 08:11 PM
Draining Battery ab02661 General Tech 4 08-10-2010 09:56 AM
Battery Tender's Sponsors Sponsors 0 10-26-2009 03:01 PM
What battery rating should I get for 1970 SBC 350? drabina General Tech 5 08-14-2009 12:02 AM
CTEK Battery Chargers/Maintainers on Special BSMExhaust Sponsors 0 10-10-2008 10:03 PM
2009 AutoForums
