Good ol' gen light on 64 impala - Impala Tech
Electrical & Wiring Troubleshooting electrical problems
Old 06-28-2011, 10:55 AM
VI-T4SS VI-T4SS is offline
Alex Barna VI
VI-T4SS is on a distinguished road
Default Good ol' gen light on 64 impala
Ok, you guys are always so helpful on here! I have run into yet another problem, lol... go figure. My GEN light is staying on even when the car is OFF and key is in OFF position. It is causing my battery to die and i am having to charge it when i want to drive the car. I have looked all over this site and others and have found a few things but thought perhaps you guys could narrow it down. The only things i found on here were when the brake was applied, or when the car was running. This is happening when my car is OFF. If this is a repeat question i apologize, but would appreciate the help. I recently replaced the ignition lock/cylinder so that would match all of the new locks on my car and also because you could start my car without the key.
Thanks again for all of your help.
Alex
Old 06-28-2011, 04:49 PM
Mr1963Convert Mr1963Convert is offline
Dan
Mr1963Convert is on a distinguished road
Default
I have the same problem on a 1963 Impala.
New battery
New ignition switch
New neutral safety switch
New Relay
New Voltage Regulator
HELP
  #3
Old 06-29-2011, 01:14 AM
Default
Well easiest solution is a disconnect switch at the battery. As soon as you turn it off get out in whatever weather you find yourself, raise the hood and flip the switch. No more problem.
What is the problem. You have a short in one of your car's wires (don't ask which one because I don't know which one it is.) I suspect it is in the charging circuit and the first thing I would check is the voltage regulator if you have a DN style alternator, or the alternator's internal diode pack if an early SI style alternator.
Other suspects are the ignition wiring or the ignition switch. The brake switch or the Hi-Low dimmer switch on your floor boards, as both have a lot of power going through them, or the horn button or turn signal switch in side the steering column. It could be corrosion in the bulkhead connector that forms the back of the fuse block. Or some earlier idiot may have some non-factory wire plugged into the fuse block that powers some accessory (like a non-stock radio) that is drawing from the BAT terminal.
There are as many possibilities as there are wires in your car (and there are more in your car than you think there are). This is why 95% of all electrical problems are fixed by replacing the entire wiring harness. This is because it is too labor intensive (unless you are working for Jay Leno on one of his rare cars) to attempt to diagnose an electrical problem going over and testing every circuit for ground, continuity and resistance, as well as measuring the amperage it conducts to eliminate it as the cause of your problem.
You can buy an universal kit from Painless or American Wire and save money if you are good with electronic circuits; or a direct fit original OEM replacement reproduced part that costs a lot more from one of the repop houses, and just replace what you have now.
  #4
Old 06-29-2011, 02:34 AM
Big B Big B is offline
Big B
Big B is on a distinguished road
Default
I have the same problem in my 64, my gen light stays on with they key off. Soon as the engine is started though it comes off, then on when car is shut off. I replaced ignition switch, lights, dimmer and wiper. Now I just do like Big Dave says, put a disconect switch and your done.
  #5
Old 06-29-2011, 08:30 AM
fsc66 fsc66 is online now
fsc66 is on a distinguished road
Default Gen light
I would get out my trusty assembly manual or service manual and trace first the generator light wiring and go from there. These problems may be as easy as a faulty ground.
Paul
__________________
Paul
1966 Impala SS
Please Visit our new site:
http://www.winvoices.com/
1960 through 1970 window stickers, car shippers, dealer invoices, retail sales orders and tank stickers, expertly reproduced, for all Chevrolet Models.
  #6
Old 06-29-2011, 10:21 AM
dcairns dcairns is offline
David
dcairns is on a distinguished road
Default
Try unplugging the connector to the voltage regulator and see if it goes out. If so, replace the regulator. I would recommend a solid state regulator. I went through 3 standard replacements, none of which worked right, then I got this one
http://www.qualitypowerauto.com/catalog.php?item=140
and it works great.
__________________
1964 Impala 4 door sedan
My Bloggy Thing: http://www.impalas.net/forums/blog.php?u=2285
Tags
1964 impala, gen light, generator light
You may not post new threads
You may not post replies
Forum Jump
Similar Threads
1967 IMPALA Generator light? 67impala94 Electrical & Wiring 17 02-05-2016 11:05 PM
gen light goes on when brake pedal applied aldo boselli Electrical & Wiring 10 01-06-2012 03:18 PM
1963 Impala passenger side parking light problem Z327GMC Electrical & Wiring 4 03-11-2011 03:36 AM
Gen Light dcairns Electrical & Wiring 2 12-29-2009 04:14 PM
GEN Light glows dim on my '68 ed68 Electrical & Wiring 2 05-09-2009 05:40 AM
2009 AutoForums
