Vortec Head Rebuild - Impala Tech
Performance Our High Performance Area
Old 10-14-2011, 05:24 AM
68ImpalaABN 68ImpalaABN is offline
Brian
68ImpalaABN is on a distinguished road
Default Vortec Head Rebuild
Bought a set of used Pro Topline heads, pn 2236494906, from a junk yard recently. I'd like to completely rebuild them. I plan on using a Comp Cams xe268H cam, but would like the heads to be able to handle a higher lift cam just in case. What parts would you all recommend? This includes replacing the valves, springs, etc.
Old 10-14-2011, 05:10 PM
Big Dave Big Dave is offline
Default
Which bates the question as to which heads are we talking about? Pro Topline was an Australian head caster that went out of business a decade or more ago. The molds drawings and rights to the complete Pro Topline line of heads including the foundry where purchased recently by the former Racing Head Service corporation (a company that went bankrupt about three decades ago but before it died it had spun off their line of cams and springs as separate company which was doing business as Comp Cams.
Comp Cams has resurrected the old RHS logo and is using old Pro Toplline heads to get back into the head casting business again as nothing succeeds in today's business world like a monopoly. They RHS also doing business as Comp Cams claims to be developing all new head designs using their labs and CNC equipment to create competitive heads at a competitive price.
But the question I ask is are you referring to a GM casting Chevrolet small block head that has a saw tooth pattern on one end, or a set of somebody else's heads? The Chevy heads are easily identified by their unique casting mark:
here is the side view of the head:
Note the extra bolt hole on one end.
The Vortec heads are valve lift limited to 0.480 inches stock and at best can support 0.520 inches of lift at the valve when fully machined. Here is a machined head showing the finished work on the left and stock machining on the right. You have to cut a larger spring pocket and cut down the valve stem guide to use PC oil seals to get 0.520 inches of lift.
You may not post new threads
You may not post replies
Forum Jump
Similar Threads
Power steering pump rebuild sandiegohat Brakes & Suspension 3 04-26-2011 11:07 PM
Vortec Heads - Big HP Jump! George65Impala Performance 9 02-18-2011 09:02 AM
head gasket install Qs Nodak Engine 2 09-25-2010 09:27 PM
Novice 700R4 Rebuild Possible Headrage Transmission & Driveline 5 06-15-2010 08:36 PM
283 rebuild kit VI-T4SS Engine 10 06-23-2009 09:27 AM
2009 AutoForums
