1965 dash fascia removal - Impala Tech
General Tech For best results use forums below.
Old 10-28-2011, 05:50 PM
mariodom214 mariodom214 is offline
mario
mariodom214 is on a distinguished road
Default 1965 dash fascia removal
Whats the easiest way to remove the front dash plate and glove box door..need to remove for pant.... ..The upper part is in really good condition no chips or scratches and all gages and light work so no need to remove the whole dash ....
1965 bel air
Click image for larger version
Old 10-28-2011, 09:34 PM
Big Dave Big Dave is offline
Default
Glove box door is easy to remove; just unscrew the three to four screws holding it on to the dash. The dash itself is a lot more involved so I suggest you take lots of photos as you bag and tag every part removed.
  #3
Old 10-28-2011, 10:22 PM
dadstoy dadstoy is offline
Larry
dadstoy is on a distinguished road
Default
Ive pulled a few out of parts cars. They are not real easy.
  #4
Old 10-29-2011, 05:22 PM
mario
Default
So no easy way to just remove the metal part of the front dash right......
  #5
Old 10-29-2011, 06:26 PM
Default
Actually a lot of the metal part of the dash can not be removed at all it is welded to the car. There are assemblies bolted into the dash that can be unbolted (screwed in actuality), but things like the controls for the heater have cables that are attached to the heater assembly which doesn't let go with taking half the car apart, the speedo cable can be unscrewed to allow you to remove the instrument cluster but it is wired in to the car and it is important to get it plugged back into the correct sockets when you take things apart, not to mention lowering the steering column and disconnecting the indicator needle in the dash from the linkage before you do.
Recommend buying a copy of the factory service manuals and even a Chilton's repair manual for your year car to have a fighting chance at getting everything back together again.
  #6
Old 10-29-2011, 06:37 PM
Larry
Default
The instrument cluster comes out with the metal part. Then you separate it once out. You have to disconnect the wiring harness, and speedo cable and drop the steering column down. Much the same as Big Dave described. And do it carefully as much of the dash is not reproduced.
You may not post new threads
You may not post replies
Forum Jump
Similar Threads
1965 Starter - Park Lights - Dash Lights Problems kraneking Electrical & Wiring 2 07-17-2011 03:22 AM
'61 dash fascia words Buggin58 Interiors 4 06-21-2010 07:15 PM
'61 Original dash fascia lines? Buggin58 Restoration Corner 2 06-17-2010 12:00 PM
'61 How are the original dash fascia lines Buggin58 Interiors 1 06-15-2010 11:23 PM
problem with my new car (oh dear) kustomladz Engine 17 05-30-2009 10:24 AM
2009 AutoForums
