Hook up vac line/bench test brake booster - Impala Tech
Brakes & Suspension Conversion Questions & more
Old 01-06-2012, 05:46 PM
liljoe66 liljoe66 is offline
Joe
liljoe66 is on a distinguished road
Default Hook up vac line/bench test brake booster
Howdy all,
Upgrading my 65 4 door to disc front brakes, replacing the master cyl with booster and dual chamber master cyl from a 69. Does anyone know where to hook up the vac line on my rochester quadjet? Also, will I need to increase the brake line size on the front brakes from the old drums? If anyone has ever changed their system over and has photos of their booster setup at the carb and the prop valve I would greatly appreciate it. Also any photos of how the lines are split once they leave the prop valve and go to the wheels.
I purchased the 69 impala brake booster used and was told that it worked when the car was parked however I would like to bench test the booster before installing. Does anyone know how to bench test the booster without acutally hooking it up?
Old 01-06-2012, 10:23 PM
Big Dave Big Dave is offline
Default
1.) Does anyone know where to hook up the vac line on my Rochester quadjet? It goes into a hose barb elbow fitting that screwed into the intake manifold originally. You would use the same hole in the manifold with a vacuum brake hose barb on one side and a vacuum line on another face of the hexagonal fitting with power assist brakes. The three eighth inch Vacuum brake hose also has a one way check valve to keep your diaphragm from loosing vacuum when the car is off.
2.) Also, will I need to increase the brake line size on the front brakes from the old drums? NO!
3.) If anyone ... has photos of their booster setup at the carb and the prop valve I would greatly appreciate it. Also any photos of how the lines are split once they leave the prop valve and go to the wheels. I will look to see what I can find in my collection of car show photos for a stock set-up, might have an informative photo.
4.) Does anyone know how to bench test the booster without actually hooking it up? You will have to bench bleed it to get the air bubbles out any way. You will need a tube and flare compression nut to run fluid out of the master cylinder and back into the reservoir for both front and rear ports. You can buy a piece of 12 inch long brake line at NAPA and also find the master cylinder fittings in the Weatherhead cabinet (ask the counterman for help finding the fittings and bring your master cylinder along to verify they fit). Then just fill with fluid and push in the back of the master cylinder until you get no bubbles. It is ready to install at that time.
  #3
Old 01-06-2012, 11:36 PM
Fossil_Fuel Fossil_Fuel is offline
craig
Fossil_Fuel is on a distinguished road
Default
" Does anyone know how to bench test the booster without acutally hooking it up? "
The only thing you can really check on the booster is if it holds vacuum or not and also see if the check valve is working.
You will have to find some vacuum line adapters to fit a vacuum pump onto the booster. Pump it down and see if it holds pressure without leaking. You can just try and blow into the booster to see if the check valve is working.
__________________
64 Impala SS 327/300 survivor
67 Impala SS 327 triple black hardtop
67 Impala Bench Seat 4 speed
http://craigaacars.shutterfly.com/pictures
  #4
Old 01-07-2012, 08:18 PM
dcairns dcairns is online now
David
dcairns is on a distinguished road
Default
I used to have a 350 based 383 in my 64 with a Quadrajet carb.
You can see the booster's vacuum hose coming from the right of the picture to the manifold vacuum fitting behind the carb.
How the brake lines were hooked up with this kit. I can't recommend doing it this way, it looks very messy.
__________________
1964 Impala 4 door sedan
My Bloggy Thing: http://www.impalas.net/forums/blog.php?u=2285
  #5
Old 01-09-2012, 04:38 PM
Joe
Default
Thanks for the advice and the photos. I will look at the back of the intake manifold when I get home tonight and see if mine has the fitting on the back side. It may just have a plug in it as this vehicle never had the Manifold Pressure dash gauge installed. The plumbing for the prop valve looks pretty straight forward however should I use both forward ports on the prop valve for left and right front brakes (as photo shows)? Or should I use a single port to a T fitting with the second port capped like my brakes are now plumbed?
Again thank you BigDave and all who are willing to help the "mechanically challenged" like myself. Just bought this vehicle 9 months ago and have already learned so much about 60's technology. Any suggestions on books/references for rebuilding a 327?
  #6
Old 01-09-2012, 05:46 PM
Default
Originally Posted by liljoe66 View Post
... Any suggestions on books/references for rebuilding a 327?
Here is a good one!
Amazon.com: How to Rebuild Your Small-Block Chevy (9781557880291): David Vizard: Books Amazon.com: How to Rebuild Your Small-Block Chevy (9781557880291): David Vizard: Books
You may not post new threads
You may not post replies
Forum Jump
Similar Threads
Brake booster Vac. Mr1963Convert Brakes & Suspension 1 06-12-2011 03:14 PM
Brake booster question Mr1963Convert Brakes & Suspension 7 11-26-2010 10:03 AM
drum brake booster for sale pacey Brakes & Suspension 7 09-01-2010 07:02 PM
brake booster on 62 owlhoot Brakes & Suspension 3 10-31-2007 08:00 PM
on disc brake conversions - booster or not? uniquebrett Brakes & Suspension 4 05-29-2007 12:11 AM
2009 AutoForums
