Official Sponsor of Team Impala |
| Impala Tech Current Topic: 61 Convertible resto. Found in a ditch | ||
Welcome Forum New to the site? Introduce yourself. |
Thread Tools |
#1
Hi. just doing a google search and found the site. Im building a 61 Impala convertible from the ground up, so far doing it all myself. This is my first attempt at a car this bad since it was had been sitting in a ditch for the past 20 plus years.
![]() ![]() ![]() ![]() this is about where Im at with it now 7 months later thanks to a donor 62 buick convertible and two 4 door 61 Bel Air donor cars. ![]() Im about ready to start on the floors then I will have the car blasted. Last edited by Skim; 06-17-2009 at 12:12 AM. |
| Sponsored Links | |
Advertisement | |
#2
Welcome to the board. Looks like you are making progress. Keep us updated.
__________________
1964 Impala 2 Dr HT 4 sp posi 1969 Camaro before and during http://rides.webshots.com/album/546302474IrnbEH 1969 Camaro almost done http://rides.webshots.com/album/553646077CLCZBu 1969 ElCamino SS http://rides.webshots.com/album/546349285mMtINq |
#3
Scary stuff. You going to put a roll bar in it this time around?
Great workmanship. You must be daring to tackle such a project with only 4-doors and a different make for parts. You can certainly be proud of your efforts. Big Dave |
#4
Excellent job so far....was one of those donor cars a 4 door hardtop, by any chance? I need a couple of rear door glass channels.
#5
Unfortunately they were 4 door post cars. I checked out your build page, that car looks super solid. Even your inner fender headlight mud shields look excellent and those are always rotted!
#6
Thanks. heres a quick rundown of what Im doing. I know some of my welding isnt the greatest due to lack of experience but Im getting better as I go. 61 Impalas are my favorite year and I always wanted a convertible but a descent driver runs 25 grand and up. I figured as long as it was a vert I will do whatever it takes to fix it. As for the car itself, It was pulled from a ravine up in Lawton Oklahoma. It had another car drug over the top of it so basically it was bad. With a couple donor cars I am determined to fix it. Anyways heres some pics and I will post more as I go. Heres some pics of the floor, once I cleaned it out. ![]() ![]() ![]() ![]() ![]()
#7
tore into that bashed front clip and started taking apart the 4 door parts car.
#8
This is the 4 door I picked up for $700. Buying a parts car is the best thing I could have ever done because it tells me how everything is put together and I have never tore into a 61 before. :0 Look at them solid *** rear quarters. This bitch is getting sawzalled for reals.
#9
converted the 4 door bel air trunk to an Impala trunk
#10
![]() ![]() ![]() ![]() ![]() ![]() Before: ![]() Donor from the 62 buick rag: ![]() Started removing the rusted out cowl.
#11
After cutting the donor out of that buick ragtop, I had to disassemble it. 10 million spotwelds it seemed like, took forever This was the hard part because since I was going to be using this part, it had to be really nice and I couldnt go crazy risking it getting all screwed up.
![]() after a quick test fit, theres a couple edges I will grind down and it should drop right into place. ![]() The next thing I will do is rust proof the rail and the back side of the panel with POR 15 to keep it from ever rusting. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#12
Luckily all 61-62 GM made verts use the same exact vert parts so I found this 62 buick convertible on craigslist that I used for the vert ****, windows, top mechanism. It was on Craigs list for $1000, I talked him down to $500
![]() ![]() ![]() ![]() ![]() The cool thing is I already sold **** I didnt need on ebay to the buick people and made $428 so its like I only paid $75 for all the stuff I needed. |
#13
bought another 61 parts car for $400.
#14
#15
#16
wondering why I had to do this, this was the reason.
#17
#18
![]() ![]() ![]() about to work some rust holes. ![]() last of the welding and finish grinding ![]() have to cut the whole dash out for a new one. All day on the dash using the one from the 4 door. ![]() gonna have the front quarters (brand new reproduction) on . This area was rusty ![]()
#19
more work...
![]() getting ready to install the new dash. ![]() got rid of the old rusty pedal assemblies and using the ones from the 4 door. ![]() its coming along thank goodnes for parts cars. ![]() since the back side of the passenger side of the dash and windshield channel were pretty rotten I had to go this route. ![]() this was some serious stuff (for me anyways.) I was scared that it wasnt gonna work out. This should give you an idea why.
#20
This was the donor that is going in to replace that rusted out window channel and fire wall section. This is the bottom side of the windshield wiper cowl.
![]() about to go in. ![]() from the inside. remember this was all ate the hell up with rust. ![]() while I was at it, I replaced this top corner. it was rusty. ![]() This was the part I cut out. you can see the rust coming thru. ![]() I havent welded that piece fully on yet but while it was open I got to clean all the shuff out that was down in there. ![]() Prior to welding up the corners ![]() after POR 15 treatment. Never rust again
#21
rust proofing inner quarter supports
#22
dash going in
![]() ![]() ![]() its getting there. This is all practice for the barn door. Get ready its all do it yourself from now on. ![]() ![]() got the dash completely welded in.
#23
some I took after I lined up the top mechanism
![]() ![]() ![]() I wanted to make sure the windshield post still lined up square ![]() ![]() header bow lines up okay but that is the OG header bow so its kinda messed up. plus it has some small rust issues. Hopefully I will find a nicer one. Me and my buddy John tried our best to straighten this one out. ![]() finally before I called it quits.. Im going to dismantle the rack and have it powdercoated.
#24
started fitting and tack welding on the passenger replacement quarter panel.
![]() I didnt really like how the repro quarters folded over into the door jamb. They didnt have a tight sharp curve so I cut them an inch back from the OG door jamb metal and butt welded everything up. ![]() ![]() everything lined up tits. ![]() also, by doing it this way (leaving and inch of original metal next to the door jamb) I was able to make sure the factory body line was consistently correct eithout the doors having to be on the car.. ![]() yeah man, so far so good until I ran out of welding wire
#25
I bumped up from .025 wire to .30 gauge and bumped the heat up a little to make sure everything penetrated. Last thing I need is the windshield post to crack on me later down the road. No more Cold Welds!
![]() ![]() same on the passenger side... ![]() finally finished this... ![]() also finished up on that quarter panel finally. ![]() finished up the fire wall welding also. I will finish grinding this. ![]() finally finished up the top of the drivers side quarter panel. Its been sitting there tack welded for weeks and I got sick of looking at it like that. I will start on the lower patch panel and that rusted out area tomorrow if Im lucky. ![]() I also should have the trunk floor soon
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1969 Impala convertible | dz7yhp | Site Discussion | 11 | 01-26-2008 11:21 AM |
| new member...69 convertible!! | bad company | Welcome Forum ![]() |
5 | 01-26-2008 11:09 AM |
| 68 convertible Stainless trim | 1badss396 | Convertibles | 1 | 07-07-2007 10:43 AM |
| Glad I found this place! | Impholla | Welcome Forum ![]() |
2 | 01-08-2007 12:45 PM |
