No heat in my 95 impala ss. Heater core? - Impala Tech
Heating & Cooling Heating, cooling & air conditioning
Old 10-18-2012, 06:25 AM
Snook Snook is offline
Jeremy
Snook is on a distinguished road
Default No heat in my 95 impala ss. Heater core?
Heater core not leaking could it be clog up? Is this the reason for no heat? Could there be other reason
Old 10-18-2012, 10:50 AM
jayoldschool jayoldschool is offline
Jason
jayoldschool is on a distinguished road
Default
With the car hot, feel both heater hoses. One hot, one cold means clog. If both are hot, it's a blend door issue. Clogged core is the likely culprit. Flush it gently in both directions, refill, then carefully bleed the system using the bleeder on the top of the thermostat housing. Helps to have the nose up a little. Ramps or a sloped driveway will be good.
__________________
Two doors, four doors, wagons, and ragtops.
You may not post new threads
You may not post replies
Forum Jump
Similar Threads
Where to get a heater core for a 61 Impala blane gardner Heating & Cooling 10 09-11-2012 05:18 PM
1966 Impala 396 Heater Core w/AC JD_Eclectic Heating & Cooling 0 11-04-2011 06:28 PM
My 66 Impala Heater Core Replacement kwando Heating & Cooling 7 07-22-2011 11:04 AM
Is heater core coolant flow directional? Odin Heating & Cooling 6 02-23-2011 11:55 AM
2006 impala heat problem gregd Heating & Cooling 3 12-11-2010 06:30 PM
2009 AutoForums
