Powerglide interchange - Impala Tech
post #1 of 3 (permalink) Old 07-31-2006, 10:56 PM Thread Starter
I have a 1966 Impala SuperSport Convertible, it has a 327 in it and it is suppose to have a 2-speed powerglide in it, but when I bought it there was a 3-speed in it. I want to put a powerglide back in. I bought one on E-bay the guy said it came out of a 1966 chevy. I found some numbers on it. On the shaft I found 3863192 and on the pan I found C7E02D. Can I use this with my 1966 327?
Thanks.
Tom Hogendobler
tbhogendobler is offline
post #2 of 3 (permalink) Old 08-02-2006, 04:08 AM
see driveline section
69427 is offline
post #3 of 3 (permalink) Old 08-10-2006, 10:18 AM
The only thing that you will need now is the linkage set up, which is different on a power glide. I have the complete set up. if interested give me a call my number is 248-207-0516
I just remove a power glide and replaced it with a 350 turbo. Also, save your linkages off your 350, because they also are rare pieces.
chuck mcgeorge is offline
