67 Impala 396 w/ AC - Impala Tech
post #1 of 2 (permalink) Old 07-15-2019, 02:02 PM Thread Starter
67 Impala 396 w/ AC
Looking for the stock setup pulley arrangement for the AC 67 cars. My engine is not original (454 '72 ish) and I am wanting to install a short water pump and mount alternator on the drivers side as original, with the AC on pass side upper. I'm wanting to make sure I use the correct matching pulleys for the crank and water pump.
So I think I need a 3 groove on the crank and a 2 groove on the water pump, right? I'm having trouble finding good layouts or pictures for this setup. Any ideas are appreciated.
67ImpalaSSConv is offline
post #2 of 2 (permalink) Old 07-15-2019, 02:39 PM
3 groove crank 2 groove water pump and power steering and one grove on compressor and alternator.
Here is a list of the short water pump pulleys you need:
1965-'68 L35 & L34 w/o smog Base C-60/N-40 C-60
Crank pulley 3874418 3874418 3874414 3874414
Crank pulley extension N/A 3925525 3925525 N/A
Water Pump pulley 3905995 3905995 3908920 3908920
Power Steering pulley N/A 3925537 3925537 N/A
If you want the deep groove pullets off of a High Performance BBC use these
1965-'68 L78 & L89 (w/smog) Base N-40
Crank pulley 3921923 3869978
Water Pump pulley 3906656 3906656
Alternator pulley 1970831 1970831
Smog Pump pulley 3925522 3925522
Power Steering pulley N/A 3873847
