62 impala big block problem - Impala Tech
post #1 of 7 (permalink) Old 08-16-2019, 07:54 PM Thread Starter
The engine is sitting seems to me to sit at higher angle.... 1/4 inch clearance under oil pan....Do i have to put in a different pan? motor mounts?
More concerned about the angle
new photo
ID:	22610   Click image for larger version
Name:	engine angle.jpg
godtar01 is offline
post #2 of 7 (permalink) Old 08-17-2019, 12:01 PM
Looks like your clearance problem is with the hood...
That will be a real tire melt-er when you are done
post #3 of 7 (permalink) Old 08-17-2019, 03:12 PM
Is that a Predator carb on top?
Looks like you will have to leave the hood off to drive in current configuration. Great for cooling a hot power plant but not so good if you don'y have a garage to park it in.
post #4 of 7 (permalink) Old 08-17-2019, 08:26 PM Thread Starter
my concern is the angle.... see new photo...yes predator carb
godtar01 is offline
post #5 of 7 (permalink) Old 08-18-2019, 12:45 AM
You can raise the angle a little by using the upper holes on the Trans Cross Member.
When I dropped a 396 in my '62, I just used the same 283 Engine Frame Mounts.
Somewhat of an angle is normal.
I did have to change the Oil Pan as the one that came with the engine would not clear.
Member:
-National Impala Association
62BillT is offline
post #6 of 7 (permalink) Old 09-13-2019, 10:59 AM
I would also double check your driveline/drive shaft angle to make sure that isn't out of wack with the pinion. Hate to have a lot of vibration going down the road.
lovebohn is offline
post #7 of 7 (permalink) Old 09-17-2019, 09:37 AM
This is particularly an issue if you are running a 2 piece drive shaft with the steady rest bearing. That bearing doesn't deal well with loading and can be tricky to get set right. If it isn't set right the bearing will wear out in a very short amount of time and your teeth will hurt.
