427 Engine rebuild - Page 2 - Impala Tech
 2Likes
post #26 of 33 (permalink) Old 02-21-2020, 04:47 AM
Agree with Dave. Look at Valvoline VR-1 mineral non-synthetic.
post #27 of 33 (permalink) Old 03-28-2020, 08:39 AM Thread Starter
Lifetime Premium Member
Update on the rebuild
Just had a meeting with the engine rebuilder. The block was decked (numbers saved) honed, bored, oil and water passages drilled,
main bearings installed.
The pistons and rods are bought and now we are discussing cam and compression, driveability issues.
Will keep you updated and will also appreciate any feedback during the process.
Thanks Guys
Tberg
tberg is offline
post #28 of 33 (permalink) Old 03-28-2020, 07:01 PM
I used to buy race gas by the 42 gallon barrel but after 9/11 I couldn't do that anymore. It is better to buy it in small five gallon cans anyway as it goes "bad" very quickly once it is opened. A better solution is additives that actually raise the octane of the fuel (not the small additives sold by the ounce in gas stations and WalMart but in one to five gallon cans that add whole numbers to your octane.
RACE GAS | Racing Fuel Concentrate
Once you have high octane gas available to you that you can find at any gas pump (you keep your additive in the trunk and add it as you fill the tank), then you can talk about your static compression ratio.
A stock cast iron head 454 running on pump gas has 7.4:1 static compression (with dished pistons). You want pop ups to fill the void of your 118-121 cc combustion chamber heads. My L-88 and LS-7 motors that I bought as service parts had 12.5 to 15,0:1 static compression ratios. With compression comes free horsepower.
That additive by the way is paint thinner. Well, it used to be paint thinner back before every one started using water based paints. It is Toluene:
https://www.ebay.com/i/133048236007?...iABEgKN6_D_BwE
Which causes cancer in people as well as laboratory mice (why we worry about mice getting cancer is beyond me; but most of the chemicals I handled warned me to keep it away from mice). It is a paint stripper so don't spill it on your car. It also evaporates as soon as you open the can (with a boiling point in the low seventies which means it is hard to keep around in Florida). But it is what the factory puts in race gas and doesn't contain lead.
You can still buy Tetraethyllead in barrels from Germany and mix it according to these charts to obtain any octane you want:
Octane Supreme Specs
or lead phosphate as used in the aviation industry in America:
https://www.aircraftspruce.com/catal...SABEgJa5fD_BwE
Lead doesn't evaporate, but it is a cumulative heavy metal poison like Mercury that attacks your brain. Not to mention, once again it gives mice cancer, so don't let them breathe the gas fumes while you mix it.
And people wonder why I act crazy in my old age!
post #29 of 33 (permalink) Old 04-26-2020, 09:48 AM Thread Starter
just an update on the motor progression, crank balanced and polished, pistons machined for a 9.5 to 1 compression.
Ordered the cam (hydraulic roller rocker) to match my drivetrain ( turbo 400, 3:31 posi gears general cruiser).
Heads finished, hardened seats,brass bushings new seals. Almost ready to go back together.
Everybody stay safe, try to stay sane.
Tberg
tberg is offline
post #30 of 33 (permalink) Old 08-30-2020, 12:05 PM Thread Starter
Corect torque strap
I am finally ready to install the rebuilt 427. I took pictures of everything (I thought) but am having problems figuring out
how the torque strap goes back in. The cable itself is about 12 inches long with two pressed ends. I also have a four inch
bolt and nut. Anyone have any pictures of how this goes back on
Thanks Tom B.
tberg is offline
post #31 of 33 (permalink) Old 08-30-2020, 03:45 PM
Thanks Tom B.
Strap goes around the upper control arm cross shaft and the two eyelets on the end of the cable are held to the stamped steel bracket with a pin that goes through the bracket and the two eyelets. The bracket is bolted to the cast iron manifolds and use the cast iron to brace and hold the bracket in place. You can not use this system with tubular headers.
I used to have pictures of everything but when Photobucket required payment to see my pictures I walked away leaving 4,264 pictures on their server. To see those pictures I would have to find another photo sharing sight and upload everything again which is too much work for me to do again.
post #32 of 33 (permalink) Old 09-05-2020, 10:06 AM Thread Starter
hey Dave i only have the cable the two ends and the bolt. No bracket
tberg is offline
post #33 of 33 (permalink) Old 09-05-2020, 12:12 PM
It sounds like you are trying to install the anti-lift cable. This was part of a nationwide recall in the early 70's. (this happened to one of my cars back then). They were installed by the dealer and not by the factory. If you are doing a factory correct restoration, you should not put this on as long as you have new motor mounts. I have restored 5 cars in the last 20 years and none have this part nor has any motor mount broke, Don S
68SS427 is offline
