Fuel pump - Impala Tech
post #1 of 8 (permalink) Old 09-08-2010, 09:53 PM Thread Starter
Fuel pump
Team,
I've neen doing some work on my
1964 Impala. I'm running a 327. While working on it I noticed that the fuel pump was actually leaking fuel and I could see that it was comi g from the upper portion of it. It almost looks like it has a place for it to breath. My question is should there be any fuel leaking from the fuel pump or do I have a defective pump?
Number2: i went ahead and put some JB weld on the part that I saw was bubbling fuel. It stopped the leak. Did I close off the breather source?
Semper Fi,
Hector
1964 Impala SS HT
2007 Tahoe LTZ
2006 Kawasaki ZX10
2003 Yamaha R1 (sold)
1995 Impala SS
1993 Tahoe GT (sold)
1978 Buick Regal (sold)
sandiegohat is offline
post #2 of 8 (permalink) Old 09-08-2010, 11:00 PM
I think what you are saying is that little hole is a way for the pump diaphram not to create a vaccume and colapse. If you have ANYTHING comming out of this the pump is bad and will need to be replaced. Also IF this is the case check your oil to see if you smell gas, if the diaphram is punctured the gas and oil will mix.
This was my persomel experience when I allways check the oil before I run it I smelled gas, I replaced the pump, drained the oil which I found out that I almost 2 gals. of oil. 5 qts. of oil and 2 qts. of gas that leaked into the crankcase!
68imp is offline
post #3 of 8 (permalink) Old 09-08-2010, 11:22 PM Thread Starter
Its strange because for the longest time I smelled gas and I finally exami ed the fuel pump and noticed that it was wet with fuel around the outside ring. As you look down at top of the pump. I dried it off with a rag and a few minutes later I noticed tjere was fuel again. Another thing I noticed was the fuel filter not having anymore air bubbles. It's a glass filter and I have noticed that ever since I "JB"welded the hole the filter stays full. Before I did that I noticed that the fuel would drain back down after the car sat for a few minutes.
Semper Fi,
Hector
1964 Impala SS HT
2007 Tahoe LTZ
2006 Kawasaki ZX10
1995 Impala SS
post #4 of 8 (permalink) Old 09-09-2010, 12:24 AM
Correct me if I'm wrong but that hole sits above that ring? Now that it's not leaking out...it's probably leaking in. .
68imp is offline
post #5 of 8 (permalink) Old 09-09-2010, 02:31 AM Thread Starter
Before I slung JB weld on it I could see where the air bubbles were comimg out as well as fuel. It reminded me of what it would
look like if someone were to take an innertube and submerge it in water to see where the source of an air leak would be coming from.
Semper Fi,
Hector
1964 Impala SS HT
2007 Tahoe LTZ
2006 Kawasaki ZX10
1995 Impala SS
post #6 of 8 (permalink) Old 09-09-2010, 04:43 PM
That is indeed a vent hole. Any gas there and you have a defective fuel pump. This is not surprising since gasoline now contains alcohol which eats at rubber parts made before 1980 when President Carter wrote his executive order requiring alcohol to be in our gas supply to limitour dependance on imported oil. You need an aftermarket fuel pump our an origianl looking part that is gasohol compliant inside the pump.
post #7 of 8 (permalink) Old 10-24-2010, 04:45 PM
Fuel pump recommendation
What fuel pump is recommended for a 64 impala SS with a 327?
Tbuck18 is offline
post #8 of 8 (permalink) Old 10-24-2010, 05:36 PM
I would use a Holley mechanical pump. It is designed to work with gasohol. If you want an original pump A-C/Delco still makes an OEM replacement (unfortunately just not in America).
