Help reading Timing Tab - Impala Tech
post #1 of 5 (permalink) Old 11-11-2011, 08:22 PM Thread Starter
I'm new to small block Chevy's. '63 with a 283/Powerglide, all stock as far as I can tell.
I've only ever timed VW engines with degrees on the harmonic balancer.
The timing tab is perplexing to me, and I can't find more specifics using forum search.
The tab looks to have a "O" and "A" and about 16 degrees of timing? Is the O a zero, indicating TDC? If so, where do I my initial timing to be on a stock motor?
Also, while messing with the disty, I noticed that the vacuum canister coming off of it hits the intake, won't let it move any farther counter clockwise. Is that normal?
Thanks
Jon
JMc63Imp is offline
post #2 of 5 (permalink) Old 11-11-2011, 09:51 PM
Does it look like this? 0 is zero. I always put some paint in the groove on the balancer, and a line of paint on the tab where I want it timed. The lines are 2 degrees apart, so the 0 is long, and 10 degrees is longer as well.
post #3 of 5 (permalink) Old 11-11-2011, 11:10 PM Thread Starter
@jayoldschool
Yup, that's the one.
I realize it's not written in stone, but where is a starting point using this tab? (stock 283 etc)
JMc63Imp is offline
post #4 of 5 (permalink) Old 11-11-2011, 11:37 PM
I believe 4 degrees BTDC is stock. I can check my 65 manual if you need me to.
post #5 of 5 (permalink) Old 11-11-2011, 11:59 PM Thread Starter
I'd appreciate that.
JMc63Imp is offline
