Powerglide interchange - Impala Tech
post #1 of 2 (permalink) Old 07-31-2006, 11:12 PM Thread Starter
I have a 1966 Impala SuperSport with a 327 and it is suppose to have a 2-speed powerglide in it, but it has a 3-speed. I want to put a powerglide back in. I bought a powerglide off E-bay the guy said it came out of a 1966 chevy. I found some numbers on it, on the shaft the number is 3863192, and on the pan is C7E02D. I need to know if I can use this with my 1966 327?
Thanks.
Tom Hogendobler
tbhogendobler is offline
post #2 of 2 (permalink) Old 08-02-2006, 04:06 AM
C7E02D = powerglide built in Cleveland May 2nd 1967 day shift
3863192 = extention housing casting number is correct for 65 on
It will bolt up o.k. providing it's a T350 your pulling out not a T400
but you should pull the pan off and have a look for any debris in the fluid before you bolt it in and find it's FUBAR !
dave
69427 is offline
