Stuck mid swap 700r4 for my Powerglide - Page 2 - Impala Tech
post #26 of 30 (permalink) Old 02-26-2010, 08:27 PM
Originally Posted by dcairns View Post
Oh, one other thought on your spacers on the transmission mount. It is possible that may have set the drive line angle off a bit too much. Try to notice if you get any strange vibrations, as that may be due to the slight imbalace of angles you created with the spacers. Hopefully it is small enough not to matter.
Guarantee that the pinion angle is now wrong (changed from the factory setting) and it will need to be corrected or the car will suffer from drive shaft harmonic vibrations from the fact that the two angles are not canceling out the standing waves the angle a shaft makes produces in the drive shaft.
post #27 of 30 (permalink) Old 02-28-2010, 02:26 AM Thread Starter
Originally Posted by A5150 View Post
Erny,
Nice motor.
Do you have any problems with your alternator belt sqeeling when you mash the throttle?
I had that set-up on my small block with headers and the brackets would let the belt vibrate and sqeel. (hows come I cant spell that word ) lol
Brad
Thanks Brad,
I had to weld an additional 1 1/2" to that bracket to give me enough belt tension and to keep my alternator from rubbing on my slightly taller valve covers.
Nor-Cal Sticks: 1964 4dr Sport Sedan - V8 350ci 700R4
64 Sport Sedan is offline
post #28 of 30 (permalink) Old 02-28-2010, 02:31 AM Thread Starter
Without these spacers I couldn't get my HEI distributor in and I could when I had the Powerglide. How can I figure out the correct angle if its a different transmission, transmission mount, and aftermarket cross member?
post #29 of 30 (permalink) Old 02-28-2010, 09:12 AM
Aftermarket sells a small cap HEI distributors with an external coil that fits in place of the old points distributor (it is the same size).
If you would rather change the pinion angle you get an angle finder ($20 self leveling magnetic base protractor) and measure the angle formed by the output yoke. Go back to the pinion yoke and measure that angle. cut off all of the brackets and mounts on the rear axel and then reweld them back on so that the two angles are the same just oposite (one points down X degrees and the other points up X degrees) there must be an angle as they can not both be zero degrees (perfectly level) or the bearings in the universal joints will burn out for lack of rotation that moves the grease around in the cups.
post #30 of 30 (permalink) Old 02-28-2010, 06:04 PM
Read the articles here:
http://www.iedls.com/guide.html
Some good stuff there.
Tags
700r4, driveshaft, powerglide, swap
