61 Rear End Gears - Impala Tech
post #1 of 3 (permalink) Old 04-06-2010, 01:56 PM Thread Starter
Question 61 Rear End Gears
dose any1 kno what rear end gears came in a 1961 impala 283 small block, third memeber rear end, and a 3 speed manual w/ overdrive???
61bagged is offline
post #2 of 3 (permalink) Old 04-06-2010, 07:16 PM
look at at the rear end and see what numbers are there then go to www.348-409.com and see what info it gies ya, there a ton of funn stuff on that website
robklein13 is offline
post #3 of 3 (permalink) Old 04-06-2010, 07:54 PM
You have the old Hotchkiss style 8.2 inch ten bolt ring gear with bolt in axels. In 1965 GM switched over to a Salisbury style rear end made by Spicer that has been used ever since which also came in an 8.2 inch ring gear ten bolt but they are not interchangeable.
Be sure the person filling your order for a replacement gear set knows this so you do not attempt to install the wrong gear on the wrong carrier (differential).
