TKO600 in 66 427 Biscayne - Impala Tech
post #1 of 5 (permalink) Old 01-11-2018, 05:24 PM Thread Starter
I am looking at putting a TKO 5 speed into my car. Does this require the trans tunnel to be cut?
I have been finding mixed answers.
Can someone tell me which parts I need? Perhaps make me a parts list?
Thanks
superstang01 is offline
post #2 of 5 (permalink) Old 01-11-2018, 08:10 PM
Welcome to the Team!
Yes the transmission needs surgery to the trans tunnel to fit as well as a modified or custom transmission cross-member, new bigger front out put shaft on the drive shaft and probably new clutch linkage if you use a hydraulic throw out bearing.
post #3 of 5 (permalink) Old 01-12-2018, 07:43 AM
Hurst Drive line conversions offers complete conversion kits.
https://www.hurst-drivelines.com/kit...WITH%20CONSOLE
If nothing else you can use it as a list for what you need to find to piece it together.
post #4 of 5 (permalink) Old 01-12-2018, 09:43 AM
I bought my TKO-600 kit for my 66' Vert from SST. I'm happy with it and their service. I'm not really sure how relevant my info is for your 67 but, I got the tranny to fit without tunnel modifications HOWEVER, visually, I wonder if my angle is slightly too much and it needs raised just a bit.
I have about a fingers width at the tightest point. I need to double-check the angle but if I need to raise it, it would only be a minor cut at the back part of the tunnel. (SST provided a sheet of metal, but not pre-formed)
D&D and Rockland Standard Gear are 2 other excellent sources for the kit. I think D&D even beefs up some internals.
If you are a hardtop, then your trans x-member can probably just be slid back and you drill new xmember mounting holes in the frame.
with a Verts boxed frame, it's more of a pain in the *** due to the fixed mounting perch at the frame.
post #5 of 5 (permalink) Old 01-12-2018, 12:07 PM Thread Starter
Thanks for the replies! I checked hurst and american power train
also, found this link which is cool...
Tremec Overdrive Transmission - Chevy Impala - Super Chevy Magazine
