Ford 9 inch conversion question - Impala Tech
post #1 of 7 (permalink) Old 08-30-2019, 09:26 PM Thread Starter
I recently got a ford 9 housing and bought a 4.11 31 spline posi gear for my 94 impala I put it on the car but seems like my drive shaft is smaller than the U joins (yoke) does this mean I have to buy a different drive shaft? Or is this gear box with yoke not compatible with my car?
I bought this gear box
http://vi.raptor.ebaydesc.com/ws/eBa...=0&cspheader=1
Tony Dinh is offline
post #2 of 7 (permalink) Old 08-30-2019, 09:41 PM
THE yoke provided for the cast iron case is for a U-Joint Series 1310. Very common 1-1/16 th inch in diameter. Your car has a metric G3 U-joint and you will need a custom U-joint with one side of the cross a Spicer 1310 that used a snap ring to hold it in place, and the other side for a G3 metric held in p-lqace by a plastic seal.
post #3 of 7 (permalink) Old 08-30-2019, 09:58 PM Thread Starter
Do I just get something like this and replace the one I have on the car right now?
https://www.ebay.com/itm/Spicer-5-13...sAAOSwHwNbeOEh
post #4 of 7 (permalink) Old 08-30-2019, 11:53 PM
Tony, the 30 spline 8.5 in your 94 is about the same strength as the 9 inch. I suggest keeping it. Unless you are at the drag strip every weekend, on 10.5 slicks, with a trans brake, and over 500hp. Plenty of the SS guys run big power through the 8.5 with no issues.
post #5 of 7 (permalink) Old 08-31-2019, 01:06 AM Thread Starter
I already committed to the ford 9in
31 spline it’s already in my car! Haha I thougut it was a direct swap but the yolks are different the current yolk on the drive shaft is smaller than the one on the axle
post #6 of 7 (permalink) Old 08-31-2019, 01:09 AM Thread Starter
Hey do you know where I can get this custom g3 X spicer 1310?
post #7 of 7 (permalink) Old 08-31-2019, 12:56 PM
My error it is called a 3R not a G3 universal. The part you need can be found here.
https://www.dennysdriveshaft.com/c14...556_insid.html
