Ez TCU on 65 Impala - Impala Tech
post #1 of 1 (permalink) Old 10-19-2019, 10:11 PM Thread Starter
Ez TCU on 65 Impala
Has anyone installed an EZ TCU on their 65? If so, where did you find to be the best place to plug in your 12v Switched wire (pink wire)?
Did you use the fuse box or the ACC on the ignition switch?
Chris Norris is offline
