Impala Tech - View Single Post - problem with my new car (oh dear)
post #18 of (permalink) Old 05-30-2009, 09:24 AM Thread Starter
kustomladz
hello once again guys
had the starter motor refurbed and oh dear was it busted big time, things had started to melt and crack inside, i think they replaced everything except the case. got it fitted in this morning all sounded well till is started up and i got the grinding noice i had before, which i had assumed was the starter motor not disengaging.
it only seems to have started this with the new switch, the 2 times it did start with the old switch it never made this noise. is there any real difference between the ignition switch i got (http://www.vintagecarparts.co.uk/en/...tch~dashboard/) and the original, i know there different but should that make this sort of problem?
and i was wondering if i removed the starter from the switch and wired up a start button would that sort it, i know it will look horrible but i just need to get it started to i can take it to be welded and mot'd.
thanks for the help
steve
kustomladz is offline
