67 Impala Control Arm Sleeve - Impala Tech
post #1 of 4 (permalink) Old 11-05-2008, 11:38 AM Thread Starter
Hi Everyone,
I am in mid restoration of my 1967 Impala. In the process of replacing the bushing for the driver's side lower control arm I mistakenly removed the sleeve. It is no longer usable. Does anyone know of where I can find a replacement of either the sleeve or control arm ? Thanks. Matt
mmschevy is offline
post #2 of 4 (permalink) Old 11-05-2008, 01:51 PM
I just replaced all my bushings and they all came with new "sleeves". I think the poly ones need to re-use the old metal but the stock replacements come with the "sleeves" . I would suggest getting a standard relacement one like a Moog and then use the sleeve.
Fossil_Fuel is offline
post #3 of 4 (permalink) Old 11-05-2008, 02:23 PM
If you are using a metal insert (aluminum with a nylon jacket) it wouldn't be required either as the sleeve is to center the bushing and bite into the A-frame to provide the torque to flex the rubber bushing (not needed with plastic or metal bushings).
post #4 of 4 (permalink) Old 11-05-2008, 09:09 PM Thread Starter
Thanks guys
Hey guys Thanks alot for the help!!I understand about the sleeve I will be ordering one tomorrow and use the sleeve.Because I am using the poly bushing.I learned something new today.Thank you so much Matt
mmschevy is offline
