Wilwood front kit for drum spindles - Page 2 - Impala Tech
 9Likes
post #26 of 32 (permalink) Old 11-15-2018, 05:39 AM Thread Starter
What master cylinder and proportioning valve are you using ?
66 impala,283 power glide, Aztec bronze
Impala 66 is offline
post #27 of 32 (permalink) Old 11-15-2018, 06:09 AM
The proportioning valve is summitís own brand (or no brand). The MC and booster we got last year. I canít recall the name right now bit it is a popular brand. I will post when I remember.
Impala 66 likes this.
gr8dain is offline
post #28 of 32 (permalink) Old 11-06-2019, 05:12 PM
I would like to install same brakes kit, for a manual (without booster), what is the best master cylinder bore size with drums rear? 1" or less?
'66 Impala
Charly is offline
post #29 of 32 (permalink) Old 11-06-2019, 05:54 PM
Call wildwood and they will tell you exactly what master to use.
67SS is offline
post #30 of 32 (permalink) Old 11-07-2019, 06:59 AM
OK 67SS, I've sent an email to Wildwood, I'm waiting them answer.
I will post them answer, if that can help.
I red lot of forums about bore size, most of people install 1" or less. It appears that Corvette uses 1" for manual brakes. Some people said that 15/16 or 7/8 can be a good option for a better pedal brake sensation (softer).
'66 Impala
Charly is offline
post #31 of 32 (permalink) Old 11-07-2019, 10:41 AM
Bore size of the master cylinder has to match the bore size of the wheel cylinders and the stroke of the brake pedal (as well as the foot pressure required since Granny Goodwhich has to be able to drive to church). A Corvette was designed not for dentist living their second childhood (that is what a Harley is for), but to road race. It doesn't behave the way a passenger car does, and Granny Goodwich really would hate to drive one. Your leg would feel like it fell off after twelve hours at Sebring or at Watkins Glen.
post #32 of 32 (permalink) Old 12-28-2019, 05:22 AM Thread Starter
I am using a 1" bore and the top hole on the pedal for a 6:1 ratio. I could not be happier. stops the car with very little effort
