2 inch drop spindle pics - Impala Tech
post #1 of 4 (permalink) Old 09-20-2017, 06:29 PM Thread Starter
Does anyone have pictures of 2inch drop spinldes installed on a 65-67 impala/biscayne/belair?
Curious to see how it looks!
superstang01 is offline
post #2 of 4 (permalink) Old 09-20-2017, 07:37 PM
It looks like you car does right now. This is because you already have installed two inch drop coil springs front and rear. It is called spring sag and happens with age and use. If you subtracted two more inches of ride height I am sure things would be dragging. Just get down with a two by four and shove it under low lying parts of the car to see how much ground clearance you would have. (a 2x4 is actually a 1-5/8 inch, by a 3-5/8th inch board).
post #3 of 4 (permalink) Old 09-20-2017, 09:39 PM Thread Starter
My car had new springs installed when it has its frame off restoration. The springs are only 2 years old
post #4 of 4 (permalink) Old 10-01-2017, 09:52 AM
I saw this review the other day, don't know if it helps or not.
http://www.summitracing.com/parts/re...b0c8aa/mediauc
AngryForest is offline
