LinkBack | Thread Tools |
64 Impala Lowering
Hi guys,
Sorry if this has been done before.
I have a stock as a rock 64 Impala, i have stumbled across some three inch lowering springs.
Has anyone used 3 inch lowering springs, and can you show me some photos?
Just want to get an idea on how low it will sit.
I really want to do a drop spindle brake conversion but the freight from the US to New Zealand kills.
Thanks
Thanks
Sponsored Links | |||
I would recommend bagging it to drop that much.
If you are gonna run drop springs, run 3" rear and 2" front to have the car leveled.
Originally Posted by Big Dave
View Post
We don't have the abundance of parts available like you do
Originally Posted by 67SS
View Post
Yes, I've done it on a 63, and my 67, before going with air bags. You can test this by cutting your stock springs about 1/2 a coil for every inch to see how it will look. 3" drop in the front is not recommended unless you like riding on the bump stops, it will bottom out on every little bump. Also make sure you get some good shocks, designed for slammed car.
Suspension travel on your car is fully extended 13.42" and fully compressed you get 8.56" for a difference of 4.86" inches of travel. If you pull three inches out of that you are going to be riding on the bump stop or trying to pull the piston out of your shock.
If you have any doubt of this for free you can pull out your spring after marking it three inches above the pigtail in the spring socket (or below as I can not recall which end of the spring has the pig tail and which is open). Cut at the mark and reinstall your three inch lowering springs. Drive it around for a while. I will bet you will soon give up on this idea.
Lowered cars are a car show thing. Great for selling magazines and getting Ooohs and Aaaahs at a car show, but you will need a trailer to get your car there. No one ever mentions this in a car magazine write up.
If you want the frame dragging the ground you have to lower it from ride height by way of hydraulics, or give up on the idea of driving the car. The reason air bags are expensive (states side you can steal a full air bag system out of a Lincoln Continental Mark whatever, or an old Peugeot Citroen as both used a hydraulic suspension from the factory) is because it is the cheapest way to lower a car and still be able to drive it.
Thanks guys,
I've already got some better shortened shocks ready to go in. Im not looking to drag the car along the road while driving. Just trying to make it look a little better and removing some of the cloud like feel when going round corners.
Perhaps i might start with a 1 inch drop spring and 2 in the rear to level it
Sponsored Links | |
Thread Tools | |
Posting Rules | |
