Manual drums w/ single boar to a dual - Impala Tech
post #1 of 3 (permalink) Old 08-04-2019, 07:40 PM Thread Starter
Hey guys if anyone has a part number for this swap. Its a 64 with 283. Not looking for performance just cruising. I just want the safety factor. Also should i add an adjustable proportioning valve for the rear. Thanks.
FireGuy153 is offline
post #2 of 3 (permalink) Old 08-04-2019, 08:32 PM
You want a 1967 Impala drum drum (not drum disc) master cylinder. AC Delco 18M1027. No prop valve needed. You can get a two in three out brass block from Inline Tube, or, use your old one and plug one port. On the master, FRONT port to front lines, rear port to the rear line. Not like later ones.
post #3 of 3 (permalink) Old 08-05-2019, 11:56 AM Thread Starter
Very good. thank you.
