Stock front spring length? - Impala Tech
post #1 of 9 (permalink) Old 12-25-2019, 09:24 AM Thread Starter
Iím working on re-doing my front end and suspension on my 66 Biscayne and have removed both front springs now. The car was significantly lower than stock before I took it all apart and removed the motor. Once I had the springs out, I noticed that it appeared the my had been cut by a previous owner but I do not know how many coils were cut off or for that matter if these are, in fact, stock springs.
I measured both and saw that one was 14 15/16 inches long while the other was 15 1/4 inches long. Iím looking to find out what the factory length is of uncompressed stock springs so I have a better idea of how much was cut from them previously. The car sat at approximately 25 1/4 inches from the ground to the top center of the front wheel well with everything installed and 245/45/18 tires.
I liked the way the car sat before so Iím trying to have it sit at the same height. I donít know if the current springs are old, worn out factory springs or if they had be replaced with newer ones with could cut out. I planned to add disk brakes and use a 2Ē drop spindle. Iíve also considered using adjustable coil overs but Iím at a stand still until I can get a good grasp on what I have already. Iíll add a few pics of the springs and how the car sat previously to give some visual reference. Thanks in advance.
camware is offline
post #2 of 9 (permalink) Old 12-25-2019, 09:26 AM Thread Starter
camware is offline
post #3 of 9 (permalink) Old 12-25-2019, 09:27 AM Thread Starter
camware is offline
post #4 of 9 (permalink) Old 12-25-2019, 09:31 AM Thread Starter
camware is offline
post #5 of 9 (permalink) Old 12-25-2019, 10:41 AM
On the MOOG web site (and likely others) you may find a very large chart of all their springs and their specs. Find your car and retrieve the info.
Merry Christmas.
Pete
japete92 is offline
post #6 of 9 (permalink) Old 12-25-2019, 11:06 AM
All factory parts were identified with an attached part number. Small trim pieces came in a cardboard box with the number on the out side. Blocks and heads and any other cast part had a casting number with a date code on the piece that allowed it to be identified. Hardened steel parts like bolts, sway bars and springs had a pice of colored tape attached to the part, all sheet metal and other mild steel parts were stamped with a die identifying the part.
In your case the original paper tape is long gone. Though the springs were not painted and the only corrosion protection was a black oxide finish (a form of rust that protected the part for at best half a year from further rusting) so they would appear as rusty metal today. Yours appear to have been powder coated or painted with an epoxy paint, which isn't stock. Who made the spring I have no idea. Factory used Moog as a vendor for most springs for cars; heavier trucks got a Moog or an Eaton spring.
Springs are identified by their wire size, coil diameter, spring rate, their free height, and the way the end of the spring was treated (ground flat, twisted into a pig tail, or left open). You can easily measure all of the attributes, except the spring rate which you can measure if you can place the spring in a holding fixture and apply weight on top of it to determine how many pounds of weight it takes to compress the spring one inch from the starting point. With this information you can order replacement springs to match what you have now.
Old springs sag with age so even though the wire size and the spring rate do not change, under the weight of the car given enough time the free height changes lowering the car from one to two inches from when they were new.
The factory spring rate was very soft compared to a Corvette or a Camaro SS or a Chevelle SS. A Trans Am raced Z/28 had a spring rate approaching 517 pounds in the front coils. A full size car was closer to 230 pounds. This is why a Trans Am racer can be seen carrying the outside wheel in the air on a tight turn with the car body flat. Compared to an Impala that would have sparks coming off the lower valence on the inside corner side was being ground off by the asphalt as the car body was about to roll over (the opposing outside tire would be hanging down rolled under at maximum extension, but not offering any traction).
If you want to improve your autocross times you have to install a massive anti roll bar front and rear, and stiffen the spring rate, as well as installing wider tires on stronger than stock wheels, which will adversely affect your ride comfort. You can turn a full size Chevy from a land barge into a corner carver, but few do as they buy the car for interior room and ride comfort, not to race it. I moderate this board not because I restore old cars, but because I had a pair of B-bodies that I actually raced (Warning they were sleepers, or a wolf in sheep's clothes that would embarrass a Mustang or import car). No one else on the Team owned a full size car so I was volunteered to moderate this board in the beginning. I owned a full size car because I couldn't fit in a Camaro due to my size, but I wasn't going to accept the stock full size car performance so I changed it so it out ran and turned inside my Camaro owning buddies.
post #7 of 9 (permalink) Old 12-26-2019, 02:04 PM
Total rebuild. 66 impala
Need advise on where to order my parts. I am finding several kits. Several companies and several combinations. Complete steering and suspension rebuild. 454 BB
Rpinney1 is offline
post #8 of 9 (permalink) Old 12-26-2019, 07:56 PM
Skip the "kits" full of Chinese junk and go Napa Gold for the steering & suspension wear items. Buy once, cry once.
68WASAGOODYEAR is online now
post #9 of 9 (permalink) Old 12-30-2019, 09:33 AM
Try these folks:
https://www.eatondetroitspring.com/
Also, with the suspension changes you're making, you'd be better off building with stock height springs and seeing if the drop spindles lower the car enough for you.
Nothing quite like bashing your spotless competition headers on a 3" curb.
justjohn is offline
