Brake booster question - Impala Tech
post #1 of 8 (permalink) Old 11-24-2010, 03:01 PM Thread Starter
I went from this
to this
Now I want to add a Brake booster.
What size brake booster will fit without hitting the valve covers?
9" dual brake booster or 11" dual brake booster
Also what size master cylinder bore should I be using?
1" or 1 1/8"
I have drum brakes on all 4 wheels now. NOT changing to disc brakes on front.
Thanks
Mr1963Convert is offline
post #2 of 8 (permalink) Old 11-24-2010, 03:41 PM
Leave the master cylinder alone (the only reason you would change over is to compensate for the different rod end on a manual versus a power brake system The Manual has a little dimple in the back , but the power brake has cup to hold the rod. There should be enough thread on the brake pedal rod to compensate for the difference in length (if not buy an aftermarket threaded adjustable brake pedal actuator rod).
The single eleven inch vacuum diaphragm should work just fine unless you have a lumpy, rough idling cam in your motor. The dual nine, or eight inch vacuum diaphragms are designed to accommodate tall deck big block engines with tall valve covers that eat up a lot of real estate under a hood and have ridiculous cams stuffed into the BBC motor such that it generates less than twelve inches of vacuum at idle.
Race cars use hand activated brakes that have a big spring to push the lever forward to quickly release the brakes and rely upon a parachute to drag the car back down from over two hundred miles per hour to eighty before you apply the brake lever again to slow the car down enough for the turn into the pit area. They don't use vacuum powered assist for their brakes so they can have as radical a cam as they want on a race car and not worry about street manners as they never drive on the street.
post #3 of 8 (permalink) Old 11-25-2010, 12:26 AM
Just remember that if you go too large on the booster diameter, you could have trouble getting your vavle cover off without unbolting the booster from the firewall. The 9" booster I have in my 64 allows for the valve cover to be removed.
Here is one for ya:
http://cgi.ebay.com/ebaymotors/1963-...item3f0526648e
dcairns is online now
post #4 of 8 (permalink) Old 11-25-2010, 12:21 PM Thread Starter
Ad says 9" single diaphragm brake booster. I was thinking of maybe going with a dual 9". Looks like the 9" would clear the valve covers better.
post #5 of 8 (permalink) Old 11-25-2010, 01:12 PM
There were two types of boosters offered in 64, probably the same in 63. Look at your shop manual. One is the Delco Moraine like I have, the other was Bendix. The Bendix is much thicker, but I don't know if it was dual diaphram.
Have you tried callin a supplier like ABS Brakes? They know this stuff and can point you in the right direction.
post #6 of 8 (permalink) Old 11-26-2010, 02:54 AM
I got a kit from SSBC with a 9 inch booster and I had to go to stock height valve covers due to the booster almost hitting the tall covers and breather (about a 1/4inch clearance, was no way I could get the cover off with the booster on) I have Vortec heads and I have to leave the last bolt in loose to pull the cover off, I cant pull the last bolt out it hits the booster. Probably not a issue with old style covers though.
Big B is offline
post #7 of 8 (permalink) Old 11-26-2010, 03:04 AM
if you wanna see pics let me know, I cant figure out how to upload them on here lol
Big B is offline
post #8 of 8 (permalink) Old 11-26-2010, 10:03 AM
Lifetime Premium Member
I have SBC 350 with tall valve covers and 8" dual booster. Fits no problem with enough clearance to pull the valve covers. If you need picture, PM me and I will post it here.
drabina is offline
