Question about UMI Rear Suspension Installation - Impala Tech
post #1 of 2 (permalink) Old 11-06-2011, 12:32 AM Thread Starter
Hello,
I am in the process of installing a set of UMI upper and lower control arms and a 12 bolt rearend into my 66 Impala. I just installed the lower comtrol arms about an hour ago, and I noticed that they had some side to side play in them with the bolts tightened fully. I don't have the rearend installed yet, and the arms are just hanging there. Is this normal, or do I have a problem? This is my first Impala and I have never worked on a rear suspension that uses a trackbar, so please forgive me if this is a stupid question. Thanks in advance for any help that you guys can provide.
powerpack is offline
post #2 of 2 (permalink) Old 11-06-2011, 12:15 PM
Originally Posted by powerpack View Post
Hello,
This sounds normal. If there is no play at all, you're more likely to get binding as your rear end tried to move. This play in the lower arms is not significant as you have to look at the whole system together, with all components in place.
05snopro440 is offline
