Master Cylinder Bleeding - Impala Tech
post #1 of 4 (permalink) Old 06-21-2012, 02:59 PM Thread Starter
Not an Impala application but the same issue. I was having air bubbling out of the rear reservoir ( front brake circuit ) on a 90 Silverado with RWAL system.
I purchased a new master, bench bled it to the point where there was fluid motion and not arieation of fluid. I used the plugs that came with the kit and followed instructions. I bled this way for a good 30 mins. and installed this with the plugs installed.
When I installed the hard lines to bleed the system; the rear reservoir again had air again. What am I not seeing here? I've heard that masters are hard to bleed, so do I need to re-bleed the master with the "tube submerged in resevoir "style again?
Pedal is more firm but still feels like I'm compressing air. Any help?
68imp is offline
post #2 of 4 (permalink) Old 06-21-2012, 03:45 PM
I have a Power Bleeder that I have used to bleed dry systems on everything from a 69 E-Type to a motorcycle. Easy to use and always works. If you a doing your brake work alone, I highly recommend looking into one.
justjohn is offline
post #3 of 4 (permalink) Old 06-21-2012, 07:03 PM
I also have an air over hydraulic bleeder but before I bought that one I used a Mighty-Vac hand pump to bleed ther brakes. It works just as well only it takes just a bit longer (time is usually not an issue if you are not running a garage working flat rate) and it is a fraction of the cost (about a tenth).
http://www.amazon.com/Mityvac-MV8000-Automotive-Test-Bleeding/dp/B00265M9SS
post #4 of 4 (permalink) Old 06-25-2012, 10:25 PM
Gravity bleeding works also if your starting out with a dry system..
Fill the master cylinder, then just open each bleeder one at a time and till fluid starts to come out.
After you have done all four, then have some get in the car and pump the brakes and hold them and then open the bleeder.
It usually take a few time to ensure all air is removed.
iraqivet01 is offline
