Lwr rear adj arms - Impala Tech
post #1 of 4 (permalink) Old 06-29-2012, 05:34 PM Thread Starter
Lifetime Premium Member
Lwr rear adj arms
Is there anywhere I can find some rear lower adjustable control/trailing arms?
Tugbeezy
TUGBEEZY_HEAVYCHEVY is offline
post #2 of 4 (permalink) Old 06-29-2012, 06:19 PM Thread Starter
1962 impala
Tugbeezy
post #3 of 4 (permalink) Old 06-29-2012, 06:59 PM
The upper arms are generally the adjustable arms so that you can dial in your pinion angle which is affected by raising or lowering the car. The industry refers to lengthening or shortening of the upper control arm as adjustment which it technically is.
Changing the mounting point (raising and lowering the arm) would affect the instant center. It could eliminate or reduce wheel hop in many cases. It also affects how the car reacts to engine torque to transfer weight better. But there are no parts because no one considers a car this big to be a sports car.
post #4 of 4 (permalink) Old 06-29-2012, 09:02 PM Thread Starter
Thanks big Dave
Tugbeezy
