Rear Wheel/Tire Size questions - Impala Tech
Wheels & Tires What fits?
post #1 of 7 (permalink) Old 09-24-2017, 09:58 PM Thread Starter
I am looking to put a bigger wheel and tire on the back of my 66 Biscayne. I would like to stick with a 15" rim. What is the widest I can go with, without modification? What is the widest tire without modification? What backspacing should I use?
Thanks!
Jeff
superstang01 is offline
post #2 of 7 (permalink) Old 09-26-2017, 02:56 PM Thread Starter
anyone?
post #3 of 7 (permalink) Old 09-26-2017, 03:05 PM
You would have to get out a tape measure o know for sure, or buy this cheap tool to mock up any tire and wheel combination that you want to to try before you spend money money mounting tires.
https://www.summitracing.com/int/par...1201/overview/
You can not assume that the car you have has not been modified or wrecked in the past that would affect tire size. But statistically over a great number of individual cases an eight inch tire on a seven inch wheel up front, and a ten inch tire on an eight inch wheel in the back are about the biggest you can fit.
post #4 of 7 (permalink) Old 09-26-2017, 04:20 PM
I think you should be able to squeeze a 10 inch wheel, backspacing should be 5.5" which will place the wheel in the center. As far as tires 275/60/15 is safe, it will fit like a glove. I don't think you can fit 295 without some rubbing, I could be wrong.
67SS is offline
post #5 of 7 (permalink) Old 09-29-2017, 05:19 PM Thread Starter
what is the tallest I can go?
post #6 of 7 (permalink) Old 09-29-2017, 05:26 PM
that would depend on your suspension. on a 275 I wouldn't go taller than 60. 275/60/15 is 28" tall.
67SS is offline
post #7 of 7 (permalink) Old 09-29-2017, 05:30 PM
275/60/15 rear tire and 245/60 front
IMO anything taller and you start looking like a truck.
67SS is offline
