Need new wheels - Impala Tech
Wheels & Tires What fits?
 1Likes
  • 1 Post By dcairns
post #1 of 8 (permalink) Old 03-31-2020, 10:13 PM Thread Starter
Need new wheels
My tires and wheels have seen better days. Currently they are 225/70/14. Can I go 255/60/15 and what rim width and backspacing will fit my factory suspension? TY
tapeworm is offline
post #2 of 8 (permalink) Old 03-31-2020, 10:48 PM
I have a set of Diamond Back III 245/60 R14 tires on my 64. These are basically TA Radials with a white wall vulcanized on them. Keeps the stock look with good grip. Tires that wide require 7-8.5 inch wide wheels. I have 14x7 wheels. ***I think*** they have a 3.75 inch backspacing. Best to measure with a tool to see how things clear. Keep in mind, I have the stock drum brakes, disk brake conversions can move the tires further out in front.
Of course if you don't care about white walls, you have more and cheaper options in tires.
62BillT likes this.
post #3 of 8 (permalink) Old 04-01-2020, 08:32 AM
What Car?
Ted
brickwhite is offline
post #4 of 8 (permalink) Old 04-01-2020, 09:25 AM
tapeworm has a 64 Impala 2 door. Probably should put a picture of your Impala in your profile, tapeworm
https://www.impalas.net/forums/30-we...w-me-64-a.html
Oh, by the way, the 245/60 R14 spare just barely fits!
post #5 of 8 (permalink) Old 04-01-2020, 10:25 AM
What you have (tire size) is plenty for the handling ability of the OEM suspension. Larger (wider) will fit, but it would only change the 'look'; which may be your goal.
I've attached a pic of my '63 with 215/70/15r black walls on Cragar SS (direct drilled; not 'omni-fit') wheels. It has a 'look' of a car from the mid/late '60s owned by a 'kid' (me at the time). The thin (approx 1" wide) white wall tires, with the OEM wheel covers was very common among the 'Dads'. The 'thin' red line tires were mostly Pontiacs. Just history.
I have drum brakes all around. Disc brakes reduce fade from retained heat, typically produced from racing, pulling a trailer, or lots of very hilly driving. I do not drive my 63 like that. If you plan on disc brakes, you may want to plan all that out before buying wheels/tires. Moving the center of gravity outboard from the OEM position may produce unintended OEM suspension issues.
I purposely did not want more rear wheel traction (wider tires) because I have a '383' sb with a 4 speed. When I 'spin' the tires, I want the tires to 'spin'; not break parts.
Just trying to be helpful.
Pete
japete92 is offline
post #6 of 8 (permalink) Old 04-01-2020, 05:54 PM Thread Starter
Pete
Thank you. I like the look of a little more rim and a little less sidewall.
tapeworm is offline
post #7 of 8 (permalink) Old 04-01-2020, 06:08 PM Thread Starter
A couple pics have been added.
tapeworm is offline
post #8 of 8 (permalink) Old 08-24-2020, 04:42 AM
Cheers, tapeworm! If you're looking for spares for your ride, you might as well visit 4WheelOnline. They have an array of tires and rims, all coming in various brands and sizes. Feel free to contact them, lots of helpful folks on that website.
Brandon Hendricks is offline
