Better Lights - Impala Tech
post #1 of 10 (permalink) Old 03-22-2019, 03:05 PM Thread Starter
Better Lights
Anyone have a good recommendation on a wire kit for upgrading to Halogen bulbs?
FireGuy153 is offline
post #2 of 10 (permalink) Old 03-22-2019, 07:11 PM
They make Halogen bulbs to replace your bare tungsten wire bulbs.
https://www.amazon.com/HELLA-0028508.../dp/B001G7A9YS
Will only offer a marginal improvement because your problem isn't the bulb (though a small four inch can not match a seven inch bulb despite what the stylist think. Halogen bulbs just extend the life of the bulb by condensing the metal that vaporizes back onto the element instead of darkening the mirrored reflector.
To make your lights brighter increase the voltage to the bulb. Measure your voltage at the bulb and it will read nine to eight volts, due to the drop across the resistance of the bulb coupled with low amperage and low voltage from your alternator. Newer alternators output more voltage and amperage (multiplied together you get Watts which is how bulbs are sold: for example yours are only 36 Watt bulbs, compared to a 60 or 100 Watt light bulb in your bathroom).
post #3 of 10 (permalink) Old 03-22-2019, 08:56 PM
Use halogens, install a relay kit to get a full 13-14V to the lights. Easy, cheap. It will also stop your light switch, dimmer, wiring from overheating.
post #4 of 10 (permalink) Old 03-23-2019, 06:45 PM Thread Starter
So i found this full volt wiring kit any thoughts. https://www.lategreatchevy.com/headl...relay-kit.html
post #5 of 10 (permalink) Old 03-23-2019, 07:01 PM Thread Starter
Here is also one other article i found. Do u do both or just one? http://www.superchevy.com/how-to/4417/
post #6 of 10 (permalink) Old 03-23-2019, 07:16 PM
If you have an external regulator on your alternator tap into the wire that feeds the regulator located next to the Horn on the radiator core support for power. Without a draw the voltage regulator won't activate the alternator to make power. This is your battery terminal on the relay (solenoid) that is going to feed power to your lights./ You plug a wire into the old light harness (I just stick a blade terminal into the light socket) to sense when the light are on. Then run a separate wire to the negative terminal of the battery where it grounds the car body (the short small wire off of the battery cable).
That is how I would maximise power to the light or to power auxilary lights; like my 300,000 candle power CIBIE off road running lights that turns night into day; and burns the retina off any one who won't dim their high beams at night. (to quote Robert Kennedy: "Don't get mad, get even!")
post #7 of 10 (permalink) Old 03-23-2019, 07:43 PM Thread Starter
Lol. Nice. I will check it out
post #8 of 10 (permalink) Old 03-24-2019, 05:53 PM
I just put in a set of LEDs in my 66. no worries of heating issue and very bright. They work awesome
Bubs66 is offline
post #9 of 10 (permalink) Old 03-25-2019, 10:32 AM Thread Starter
Did u have to use a new harness and how much?
post #10 of 10 (permalink) Old 03-30-2019, 08:32 AM
No they are plug and play. I bought a set of vision headlights 5 3/4 and installed a set of pro performance LED bulbs and done. They cost me around 65bucks for the head lights (set 2) and i think about 160 set of 2 LEDs. Canadian bucks.
Bubs66 is offline
