1966 Impala Ignition Switch - Impala Tech
post #1 of 11 (permalink) Old 04-25-2019, 10:29 PM Thread Starter
I need some help to confirm the serviceability of my ignition switch. How many positions should be on switch i.e accessory key completely left. Off straight up and down. Run key completely right. My switch has a position in between off and accessory is this correct?
I have been having trouble keeping battery charged I sense the ignition switch is not completely shutting off. How can I determine if the switch is completely turning off? By the way all lights and gauges turn off.
File Type: jpg 996C78FA-E28B-437A-80FC-02E404F338DA_1556245712598.jpg (17.3 KB, 34 views)
File Type: jpg 84A5B99D-2E0E-49E3-B3A3-15222080A25B_1556245733381.jpg (17.0 KB, 31 views)
lndbarron is offline
post #2 of 11 (permalink) Old 04-26-2019, 11:13 AM
Sounds defective (worn out) to me.
post #3 of 11 (permalink) Old 04-26-2019, 07:11 PM
That's interesting similar issue here however a 68 not 66 only found out on a flat battery.
There are four positions on the 68 and the off position is between ACC & ON is a hard find not a positive feel .....
Now as pointed out by Big Dave (worn out) I know mine is the original key tells the story and the fact
the complete barrel comes out when in the ACC position that however ended up a bonus as the key number is on
the back of the barrel. That enabled the key cutting shop to produce a key that worked previous attempts off the
original failed. So until I need or find a vendor for replacement ignitions I found a switch on the battery a big help
be a pain if driven daily but works for me ........
ID:	22242   Click image for larger version
ID:	22244   Click image for larger version
ID:	22246   Click image for larger version
bigears is offline
post #4 of 11 (permalink) Old 04-28-2019, 10:14 PM
If I understood these posts correctly, is there a chance that your 66 was retrofitted with a 68 style switch? The 66, as you know, has three positions only. Off, On, Start. If your switch is original or the correct part for your 66, then it is most likely defective and the 'in-between' setting is making contact with the start circuit, thereby consuming battery or causing a parasitic type drain.
marsmann is offline
post #5 of 11 (permalink) Old 04-29-2019, 01:12 AM
As far as I've ever seen, all 66 full size Chevy ignition switches have ACC, OFF, ON and START.
Darth is offline
post #6 of 11 (permalink) Old 04-29-2019, 09:18 AM
That is correct, they have 4 positions
Paul
Paul
1966 Impala SS
Please Visit our new site:
http://www.winvoices.com/
fsc66 is offline
post #7 of 11 (permalink) Old 05-12-2019, 06:02 PM Thread Starter
Thanks everyone for responses, I have changed a factory correct ignition switch, and the voltage regulator. However the battery still is not maintaining charge. I have checked the battery and all tests are saying it is a good battery. When I jump the car there is a clicking in the voltage regulator when I and connecting the jumper cables. I cannot figure out why the battery will not maintain a charge. Any ideas?
post #8 of 11 (permalink) Old 05-12-2019, 06:37 PM
Paul
Apologies for any confusion. I see it was poorly worded. I am counting positions from left to right from off to crank.
To the original poster, since you have replaced your switch and regulator, have you eliminated the alternator?
marsmann is offline
post #9 of 11 (permalink) Old 05-20-2019, 07:29 PM Thread Starter
yes, if i disconnect the positive terminal car stays running. disconnecting the battery maintains a charge
post #10 of 11 (permalink) Old 05-21-2019, 01:10 PM
japete92 is offline
post #11 of 11 (permalink) Old 05-21-2019, 02:02 PM
You are playing with fire (literally) if you disconnect any positive terminal with the engine running. A fraction of a second contact with any body part gets a big spark followed by old west Indian smoke signals that state ("Kiss your fuseable link good bye").
Any electrical work done on a car should be with the battery disconnected and the ignition switch off (unless you are testing the circuit). You use meters (some are self powered with a nine volt or a 1.2 volt batter). Best tool I have found is this Chinese copy of a KD (which is a Korean copy of a Fluke) tester:
https://www.amazon.com/dp/B071LHLSBB...v_ov_lig_dp_it
