Missing firewall harness(es) for 67 convertible - Impala Tech
post #1 of 3 (permalink) Old 07-07-2019, 07:08 PM Thread Starter
Both plugs are gone from the firewall. I found classic industries has various harnesses up to about $520 for a complete set.
Question is I’m not sure what to look for online. I found a harness for the engine compartment for $120 but I doubt it includes both plugs on the firewall and everything for the engine.
The only thing I think I’m missing are those two plugs with wires on the lower drivers side. Everything inside is there.
Would I be better off getting some wiring from the salvage yard with plugs and whatever is left? I know of a few 67 sedans.
67ImpalaSSConv is offline
post #2 of 3 (permalink) Old 07-08-2019, 11:18 AM
Question is Iím not sure what to look for online. I found a harness for the engine compartment for $120 but I doubt it includes both plugs on the firewall and everything for the engine.
The only thing I think Iím missing are those two plugs with wires on the lower drivers side. Everything inside is there.
American Autowire sells all of your hanesses as separately as possible, so engine harness, headlight harness, etc. If you call they'll usually pull up the OE wiring diagram to help answer questions about what you need. They have some components that are sold separately so you'd have to contact them and ask what is available.
justjohn is offline
post #3 of 3 (permalink) Old 07-08-2019, 09:49 PM Thread Starter
Thank! I did check with them and it was about $600 for what I needed.
So, I went to the salvage yard to look over a Ď67 I knew of. It just happened to have all the harnesses I needed and they were in great shape. I cleaned them up and didnít have to fix anything (yet) I was very surprised.
Anyway for about $40 I got all I needed. Very pleased with that find!
