Dome lights stay on in my '62 - Impala Tech
post #1 of 3 (permalink) Old 08-29-2019, 01:55 PM Thread Starter
Question Dome lights stay on in my '62
OK folks:
After replacing both door jamb switches on my '62 and confirming they are working as designed (bench-tested, solid wire connections and seated in bare metal holes) the dome lights stay on when both doors are closed. Rotating the headlight switch knob doesn't shut them off either and I suspect it must be faulting internally.
Is there anything else that can over-ride the dome lights circuit?
Nascar18 is offline
post #2 of 3 (permalink) Old 08-29-2019, 06:48 PM
Power to light is always hot. It is the door switch grounding oit that closes the circuit. You have a short to groud somewhere in the dome light wiring. It is usually found under the door sill were screw or metal panel edge cuts the insulation on the wire.
post #3 of 3 (permalink) Old 08-30-2019, 01:18 PM Thread Starter
Thanks again Big Dave, I concur and will begin the always-popular wire tracing and under-dash explorations! Wish me luck!
Nascar18
Nascar18 is offline
