1966 Impala Cranks but will not start - Impala Tech
 3Likes
  • 1 Post By Big Dave
  • 1 Post By japete92
  • 1 Post By 66ssimpala396
post #1 of 14 (permalink) Old 01-08-2020, 09:35 AM Thread Starter
Hello, new to the site. My previously running 1966 Impala now will not start. It will crank, but will not run. I have checked the points, replaced the coil, new plug wires and battery. I did test the coil with the key on and do have power at the coil. I do see gas squirting into the carburetor. I have recently removed the heater blower from the firewall and heater box from the interior. I have also removed the instrument panel to replace the light bulbs and see if I can get the factory tach to work. May have had a few sparks fly while testing the tachometer, so I think that maybe this has something to do with it? It has not run since I took these things out. All indications seem to point to no spark, but I have reached my level of expertise with this particular issue. Any help with trouble shooting would be greatly appreciated.
66ssimpala396 is offline
post #2 of 14 (permalink) Old 01-09-2020, 11:32 AM
Check to see if you are getting Spark at the Plugs. Either with the old screwdriver trick or with buying a Spark tester (about the size and shape of an ink pen).
Member:
-National Impala Association
62BillT is offline
post #3 of 14 (permalink) Old 01-10-2020, 12:48 PM Thread Starter
62BillT - thanks for getting me back on track. I will check each plug this weekend.
post #4 of 14 (permalink) Old 01-10-2020, 12:58 PM
Agree with Bill there. In addition to his 2 methods, I used to take one out and lay it on the header or intake manifold and look for the spark to jump across the plug gap.
When you say you checked the points, do you mean you actually checked with an old Dwell Meter, or you used a feeler gauge on the gap, or what exactly?
Out of curiousity, if you do have spark, did you happen to try spraying any Starting Fluid into the carb to see if you get different symptom or maybe it runs for a little bit?
post #5 of 14 (permalink) Old 01-10-2020, 01:59 PM
A BBC is timing dependent (it is very inefficient and likes lots of timing to run but retarding the spark helps get it cranked; which is one reason I use an ignition box that allows me to retard spark on cranking). If you didn't get the points seated correctly on the weight platform in the distributor your timing will be way off (a good reason to buy a small cap magnetic pick-up or optical gate distributor to go with your ignition box; no points, no wear just set it and forget it).
I am more worried about the sparks.
Sparks aren't good; nor is letting out the sacred smoke from the wiring. You may have opened a fusible link or blown a few fuses in your fuse box. One of them may be the IGN fuse that powers your distributor (when cranking the power is back fed at full voltage off of the starter motor which is why it sparks on cranking but won't run).
There is a diagnostic logic tree printed in the service manual to help figure out electrical issues.
post #6 of 14 (permalink) Old 01-12-2020, 08:39 PM Thread Starter
Ok, good stuff here. I checked each plug, no spark. I checked voltage at coil with key on, and had 12V. Checked coil during crank and had a slight drop which I assume to be the normal “voltage drop”. Held coil to distributor wire to a ground and no spark. I ‘fiddled’ with the points but did not gap them with a feeler gage. Could be problem. Also curious about the ignition wire Mentioned by Big Dave. I have the diagram. Is there a test for this to see if this wire is toast? I have read about test using number from battery to coil directly but this seems like it may cause more problems?
post #7 of 14 (permalink) Old 01-12-2020, 08:41 PM Thread Starter
Also, tried started fluid in bowl, no go. Carb is squirting fuel fine.
post #8 of 14 (permalink) Old 01-13-2020, 08:55 AM
I would now proceed with a new set of Points along with a new Condenser and set with a Dwell Meter. Range is 29-31. I always go with an exact 30 on the Meter.
Member:
62BillT is offline
post #9 of 14 (permalink) Old 01-13-2020, 09:10 AM
If you are going to retain points you need to invest in a tach-dwell meter.
https://www.ebay.com/i/223831902838?...xoCDv8QAvD_BwE
BA. likes this.
post #10 of 14 (permalink) Old 01-13-2020, 03:07 PM
I do not know what 'fiddling' with the points means but the car will not start if the points are not set set properly. That may be only part of your problem(s). If the car is not running, one must set the point 'gap' with a feeler first. Re-set points with dwell meter after it is running.
To set point with feeler one must turn the engine 'over' (a wrench on the nut on the crank may be used) manually until the points are at max 'open'. Remove the distributor cap to see the point gap. Point gap for a small block is 0.019" for new points, 0.017" for 'used' (I do not know the BB gap, never tuned one). A dwell meter will allow fine tuning after the engine is running; 30 degrees is ideal. Also, changing the dwell, changes the timing.
Not saying gapping the points will get you started, but you have no chance if they are not.
Pete
BA. likes this.
japete92 is offline
post #11 of 14 (permalink) Old 01-13-2020, 04:04 PM
Originally Posted by japete92 View Post
I do not know the BB gap, never tuned one.
Pete
BBC and SBC share the same distributor. Only difference is the ignition curve which is the weights and springs used.
The tens of other part numbers reflect different combinations of materials used such as a cast iron body or an aluminum one, or whether it has a Tach drive or not. There are changes internally such as stops (adjustable) and oil tubes with bearings, or no oil tube with brass bushings. But basically all are interchangeable (with the exception of the tall deck truck BBC block which has a taller distributor).
post #12 of 14 (permalink) Old 01-13-2020, 11:56 PM
A bad condenser in the distributor also will not allow the engine to fire.
Just an old Chevy lover that has one more 65 or 66 Impala left to build when I retire in a couple of years
Theragtopguy is offline
post #13 of 14 (permalink) Old 01-15-2020, 11:13 AM Thread Starter
Fixed! It was the points gap. I purchased a new set of points with a condenser and took the time to gap properly by allowing the points to reach max open, then used feeler gauge to establish the proper gap. After a few turns, she fired up. Thanks for all of the help.
62BillT likes this.
post #14 of 14 (permalink) Old 01-15-2020, 02:56 PM
that's awesome!
