Fuse always blown up if I turn on the light!? - Impala Tech
post #1 of 3 (permalink) Old 05-27-2012, 04:46 AM Thread Starter
Hello,
I have a problem.
Until yesterday everything worked correctly in my Impala Coupe 1966.
Then I parked the car. One hour later I wanted to turn on the light.
Everytime I put in a new fuse, the fuse blowes up again. I looked at the fuse, it is the correct 20A fuse which worked perfect the last time. 20A also stands on the fuse box.
If i put in a new fuse it works:
  • the dome lights work all (if I open the door and also if i put the light switch to left for only interieur light).
  • the brake light is ok, if i put the brake, the lights are on
  • my flasher lights are ok, also if the fuse is blown up (so they are not on the same fuse)
  • I have no radio installed
  • if I put the light switch on complete, the headlight works (not the parking light) and the bright light works without problems
Where is my problem. I can drive if is is not dark. Then everything works without the tail lights and the parking light in the front and if it is not dark I don't need them.
But if it is dark I can't turn on the switch for the headlights, then my fuse blows up and I have no interieur light, no tail lights and no brake light.
I can't find any damaged wire. Is it possible that my switch is not ok or is there any other frequent problem?
Thanks a lot.
Imp66
Imp66 is offline
post #2 of 3 (permalink) Old 05-27-2012, 05:50 AM Thread Starter
I found the mistake.
In Germany we have to put the parking light into the headlights. There was a problem with the insulation of one wire.
I like old cars, you can work on them alone and there are no control boxes.
One man - one wire
Imp66 is offline
post #3 of 3 (permalink) Old 05-28-2012, 07:03 AM
Glad you solved the problem.
wogman75 is offline
