post #127 of (permalink) Old 03-26-2016, 07:16 PM Thread Starter
jayhawk500
Originally Posted by Lost in the 60's View Post
You have the seat belts correct. There are aftermarket retractors that will pull them back to the sleeve.
Bummer about the knock, but pull the inspection cover and make certain the torque converter to flex plate bolts got tightened. They will make that same noise too.
The underhood "after" pic looks phenomenal...
I do have seat belts for the outer positions. I'm looking to add a third set for the center.
Good point on the torque converter. I'm almost positive I did tighten the up when I put the bolts in, but stranger things than that has happened while doing this car.
**EDIT** I checked the bolts and only got less than 1/2 turn on all 3 bolts.
Thank you!
Chris
Warrenton, OR
'70 Chevelle
'74 Nova
'10 Camaro
jayhawk500 is offline
