post #134 of (permalink) Old 04-17-2016, 10:43 AM Thread Starter
jayhawk500
You can run the engine with rags covering the valve springs to prevent oil squirting across the garage (still makes a mess but it is easier to clean up than tearing everything down). No noise then your rocker arms are hitting your valve covers. Common complaint with roller rockers.
No roller rockers, stock rockers. I did the screwdriver to the ear trick and didn't hear anything other than the solid lifters going tick, tick, tick. The sound is coming from the center of the engine behind the water pump. I thought it was the pump, but we removed the belt and still had it.
I'm thinking cam and fuel pump rod. ????
I was in the process of building my engine sling, and ran out of welding wire. So now its a trip to the industrial store this morning for more .030 wire.
Picture to follow.
Chris
Warrenton, OR
'70 Chevelle
'74 Nova
'10 Camaro
jayhawk500 is offline
