post #137 of (permalink) Old 04-19-2016, 09:21 PM Thread Starter
jayhawk500
If you used an aftermarket double row roller timing chain it could a connecting link that might be hitting the block as it rotates. I have experienced that problem occasionally with a BBC. I had to grind the block to clear the chain going around the cam gear.
This was a running engine when I pulled it. I didn't do any engine work other than re-gasketing it to fix the oil leaks. This engine should have never failed.
Chris
Warrenton, OR
'70 Chevelle
'74 Nova
'10 Camaro
jayhawk500 is offline
