post #148 of (permalink) Old 04-24-2016, 04:24 PM Thread Starter
jayhawk500
Originally Posted by Lost in the 60's View Post
Check for clearance between the cam gear and block. If you can't push it against the block, you may have found what caused the gear to move forward and the chain to rub. That plug should just be a hair in from flush and may be a shallower plug than a frost plug. It isn't there for frost, it's just to fill the came bore hole.
As a second condition to check, see if the cam lobes are centered in the lifter bores. If they are slightly forward too, you know what to do...
Thanks Mitch, I'll take a look.
Chris
Warrenton, OR
'70 Chevelle
'74 Nova
'10 Camaro
jayhawk500 is offline
