Impala Tech - View Single Post - Transmission and Pinion Angles 1967 Impala Convert
post #2 of (permalink) Old 07-19-2017, 05:22 PM
Ya you are pretty much done at this point. It is a little better with more altitude but no one like a car that runs at the factory ride height as it is currently unfashionable. If you get a vibration due to pinion angle you can install a constant velocity joint in your rear drive shaft to remove the vibration induced by a universal joint.
