1967 EFI Fuel Tank - Impala Tech
post #1 of 15 (permalink) Old 04-12-2016, 05:10 PM Thread Starter
1967 EFI Fuel Tank
I'm looking around to see if going the EFI route on my 67 would be a realistic option and I'm having a hard time finding a fuel tank that would not have to be cut and hacked up by me.
It seems like they have a ton of 64-66 custom tanks than bypass 67 and go to the late 60's. I have compared images of a 68 tank and it looks almost the exact same. Anyone compare the two or have any idea where they might be different? The specs on Tanks Inc and a few others list them the same. If nothing else have have no problem getting a generic one that doesn't look OEM, but I also don't want to pay $1000 either. Thanks for the insite.
lovebohn is offline
post #2 of 15 (permalink) Old 04-12-2016, 09:09 PM
I would check with Rick's Tanks as he can build you a custom tank to meet your needs.
Home - Rick's Tank's
post #3 of 15 (permalink) Old 04-12-2016, 11:09 PM
You can use the 91-96 plastic tank and sender. Use whatever pump you need for your EFI.
post #4 of 15 (permalink) Old 04-13-2016, 09:58 AM Thread Starter
I sent a message off to Rick's, but from looking at their prices in the past dropping a grand for just the tank isn't hard to do.
lovebohn is offline
post #5 of 15 (permalink) Old 04-13-2016, 10:01 AM Thread Starter
Is the tank close to the same dimensions as a 1967?
lovebohn is offline
post #6 of 15 (permalink) Old 04-18-2016, 04:47 PM Thread Starter
No message from Rick's yet. I did talk with Classic Industries and they have a tank which ends up being one of Rick's but it's $1200, ouch!!
lovebohn is offline
post #7 of 15 (permalink) Old 04-18-2016, 07:12 PM
Yes, that tank is very close. You will have to make a cut in the trunk floor to clearance the sender. A buddy on another forum used this tank in his 66 when he installed an LT1 (94-96 version).
post #8 of 15 (permalink) Old 04-19-2016, 09:54 AM Thread Starter
My goal was to avoid cutting a hole in the trunk floor. Most of these EFI tanks had the recessed area for the equipment to not hit things. Or if nothing else buy something like this with a new tank and have it welded in at a local fab shop for the pump.
Weld in Fuel Pump Recess
lovebohn is offline
post #9 of 15 (permalink) Old 06-06-2016, 06:11 PM
I have my tank from my 68 Impala that I was going to use but sold the car before I could install it the tank is brand new it is from tanks inc and it already has the PA-4 pump installed neither has been ran with gasoline yet if you ae still looking for an option. PM Me
gthmcty1 is offline
post #10 of 15 (permalink) Old 06-07-2016, 12:08 PM Thread Starter
Any idea on what the difference is between a 1967 and a 1969 tank? Does the tank also have the spot for the sending unit?
lovebohn is offline
post #11 of 15 (permalink) Old 06-07-2016, 01:06 PM
Not sure if that was a typo regarding the "1969 tank" I will assume so lol, but the difference between the 2 tanks are two different part # one part # is a GM53a and a GM53 c the ONLY difference is that the one comes with a filler neck GM53c and the other does not GM53a but they are both physically the same size weight dimension, and everything essentially it is the same tank. The tank I am referring to has the filler neck attached to it already and also it does have the provisions for a sending unit unfortunately I do not have that I think they are like $30 on ebay.
ID:	15577   Click image for larger version
gthmcty1 is offline
post #12 of 15 (permalink) Old 06-08-2016, 10:20 AM
67SS is offline
post #13 of 15 (permalink) Old 06-08-2016, 10:41 AM Thread Starter
Yes the tanks look almost the same, but most sites have the years as different models, no clue what the differences are.
I wish they just have a custom EFI for the '67 like this one for the '65-'66.
lovebohn is offline
post #14 of 15 (permalink) Old 06-08-2016, 10:47 AM
The tanks are the exact same look at the measurements of the tank they are identical!! Don't be confused just because they have a different part number and I know for a fact the 67-68 tanks are interchangeable my 68 tank was test fit onto a 67 and fit like a glove!!! Give the folks at tanksinc a call really nice people!!
gthmcty1 is offline
post #15 of 15 (permalink) Old 06-08-2016, 11:04 AM
Tanksinc will set up the tank for 67 with their in tank fuel pump. The cost is around $650 shipped, depending on your FI system requirements. I have had their tank on my Chevelle for 4-5 years now with no issues.
67SS is offline
